Lancer Mini Battery kit install
This is the install of the PPI Lancer Mini Battery kit:
Tools needed: 10mm open wrench 8mm Allen 6mm Allen 5mm Allen Red Loctite (271 or 277) 1st: Remove the 0EM battery. 2nd: Remove the plastic tray: take care of removing the rubber line attached to it. There is also a plug attached to the lower corner of the tray. This will be a good time to clean the area below the tray. 3rd Install the lower part of the mini battery tray with the provided adapters using the 8mm Allen, you will use the two big holes were the plastic tray used to be: http://i85.photobucket.com/albums/k5...g?t=1180499820 4th: Install the 0dyssey PC680: http://i85.photobucket.com/albums/k5...g?t=1180500117 5th: Secure the battery with the top part of the tray using the 6mm Allen: http://i85.photobucket.com/albums/k5...g?t=1180500168 6th: Install the battery terminals with the 5mm Allen (put a small drop of loctite in the threads of the battery post cap screw) . Take note that the bigger one is the positive side (+/red) terminal. Then install the positive and negative cables and secure them with the 10mm wrench. ENJ0Y! http://i85.photobucket.com/albums/k5...g?t=1180501053 {thumbup} |
Closed. Discuss here.
