Help with water pump install
Can anyone give me some help on the install process of my water pump? I have a 2004 mits lancer ralliart.. water pump barrings i'm assuming went out and need to install a new one..
i replied your other thread...you say you're assuming the bearings are gone...you'll want to be more sure than an assumption, as you'll be removing the timing belt to replace it, pretty big job...
yes its for sure the water pump.. and its about 25000 ahead of schedule on a new timing belt... water pump is coming in in the morning.. should I get timing belts too.. Im a complete newbie at this obviously.. thats why I was trying to find specific video of my car not gallant or evo..
a 2.4L galant has the same motor, procedure will be exactly the same...chassis is irrelevant, same with the EVO...the 4g69 motor is a SOHC variant of the 4G63...
