05 Ralliart snapped timing belt
I just bought a 2005 Ralliart as a result of my 2002 Lancer ES being totaled. The timing belt broke a couple weeks ago (the reason I only paid $500) and it’s the first work needed to get back running. I work at a car shop but I’ve never done timing belts before. I’ve watched some YouTube videos and done research but I want to see if I can get more personal input from someone with mitsu experience. Any assistance on tools, procedure or anything useful is very much appreciated. Thanks in advance 😁
That's an interference engine, if your timing belt snapped your valves are probably bent. You're gonna want to pull the head to inspect it.
Originally Posted by Fox_IX
(Post 11867597)
Originally Posted by Jay Moore
(Post 11867599)
😬 I’ve heard rumors of that being the case. Definitely gonna open it up and check when I get to the shop. I really hope they’re not damaged 😭
(Post 11867600)
Be sure to check the pistons for damage from valve contact as well. It'd be wise to get ahold of the factory workshop manual for your car as it'll give you all the steps and specs you need for the job.
This is the manual I used to do my timing belt replacement (same year as yours)… Just follow the instructions in the first post and you'll have a pdf copy..
https://www.evolutionm.net/forums/la...able-here.html. |
Do I have to put the car on a lift or can it be done on the ground?
(Post 11868406)
You won't need a lift. But getting it up on jack stands and taking the tire off will help tremendously.
