Install headers n downpipe
i didnt measure the piping because i just seen this now sorry. it is the exact same as ur stock piping. i had to buys a 41/2 in grinder n ground it off in the gasket area. worked awesome, was a pain with the limited space... but i have a question i disconnected the battery for ten mins and the started it up and letit idle for ten mins its was extremely loud at first and three mins er so it quited down a little( i think the comoputer resetted itself) it sounds ok when im crusing around and not using the gas. but when i use the gas a little even a little it sounds like a lawn mower. theres this open hole under the head before it connects to the downpipe. what goes there? my stock manifold had nothing that went there. i believe the loudness of the lawnmower sound is coming from that open hole. thanks again guys for the help so far. ill take a picture in a min er too of what im taking about
hmm i checked the box for a metal plug???and i looked at the stock mani n dp nothing hoooked up any where.. i can take pix f the stock mani n dp if u guys need to help me futher.. which i appreicate.. i have no check engine light on it never did nor do i have a cel elminitor which boggles my mind its not on seeing as i have an open hole in my manifold..... hmhn anything please anyone
https://mail-attachment.googleuserco...WGF3PFgKxUbVAo
https://mail-attachment.googleuserco...DEO__IwBDY1M0A
https://mail-attachment.googleuserco..._ocgGHoxNPp9K0
O2 sensor thread is M18x1.5, you'll want a bolt length of 15-20mm (excluding the head), you should be able to buy them at your local exhaust shop, garage or parts store...this way you can remove it if you ever want to install a wideband sensor, rather than having it welded closed...also after you get it plugged, you'll want to reset the ECU again...
Crans thats what ill do today after work..thanks again really ill post when its plugged. Do u think i could leavr an old non working02 sensor n just snip the excess wire
Im omw too n from jobs as i work in the trades but was doing a little on phone research n i seen people used spark plugs?? Just throwing it out there.. id perfer a plug for my bung hole lmao but really thanks for staying with me on this
My bolts were the same way when putting my DP on... cut off wheel made short work of it...new bolts and done.
all my exhaust bolts have been like that... they cheaped out when making it, lol
I put a plug in the bung..
I got one for free from a local shop... i took it gor a spin n it started making sane noise..
Stop n noticed it almost came out after using anti seise so i used lock tight red. N reset everyrhing now it seems to be fine. Thabks guys
240Z TwinTurbo
196
Nov 3, 2015 12:29 PM
gui dube987
35
Feb 13, 2014 12:09 PM
