Aggressive Wheels on 2004-2006 Lancer
Old Nov 8, 2016, 11:53 AM
  #601
jcmaz's Avatar
I've inputted my setup (16x8 +30 on 205/50/16 tires) in comparison to yours. I don't think you'll hit the strut housing since mine doesn't and my setup is wider/more aggressive than yours. If you do get a spacer, you might want to roller your wheel arches as well.
http://www.willtheyfit.com/index.php...t2=35#isPage=1
Old Nov 18, 2016, 05:52 PM
  #602
the1ftw's Avatar
Thanks for the information, the fitment was perfect. No rubbing issues at all, not even while at full locked steering. The crazy part is even with my stock 205 50r16 I would rub close to full lock while turning.
* 17x7 +35 with 205 40r17 tires lowered on Tein Basic coilovers no issues *
Old Feb 3, 2017, 09:42 PM
  #603
Carrier's Avatar
hi i just buy new wheels 18x8 +44 on 215 tires
i need spacer for the front?
for the rear, 6mm spacer is ok?
thanks
Old Feb 4, 2017, 10:05 AM
  #604
Resurrected RA's Avatar
thanks
That's a tough one, I'll try and find the calculator, I know 18x7 and +38, 215 tires rub at near lock, on TIEN springs...
Is your suspension altered? What series of tires 35?
Old Feb 4, 2017, 04:22 PM
  #605
Carrier's Avatar
my tires is 215-35-18
my suspension is tein coilover
presently i ride with 18x 7.5 +45 on 215-35-18 without problem and without spacer
Old Sep 6, 2017, 11:37 PM
  #606
jcmaz's Avatar
I recently purchased some Continental Extreme Contact Sport tires in 225/50/16 for my R32 GTR 16x8 wheels. I am very interested to see how much I will rub with this setup and how much camber is needed to stuff these tires in the well.
Old Sep 14, 2017, 10:08 PM
  #607
jcmaz's Avatar
I got the tires mounted today. Shout out to Ilya for doing the tire mounting and coilover adjustment! At the ride height I was at before, the tires would rub at any small bump and turn. He raised the car a bit and now the car does not rub that much.
There is roughly a finger's worth of space between the tire and the lower control arms in the rear. I'll take a picture of it when I get a change. A 5 or 10 mm spacer would be better and give enough clearance but it's OK as it sits now.
There is barely any rub at full lock. My Ralliart in the photos have around 120-150lbs of stuff in the rear - my old tires, jack, extra pair of stock wheels and tires.
Here are the specs: 16x8 -30mm offset R32 GTR, bored to 67.1mm from 66.1mm. Continental Extremecontact Sport 225/50/16 tires.
Old Sep 15, 2017, 06:23 AM
  #608
bakuro117's Avatar
Very nice! Those wheels look so good on there!
Old Oct 15, 2017, 02:14 PM
  #609
Dreams Fusion's Avatar
I was wondering if it's the stock height of the vehicle with stock coil springs. I am thinking about putting 205.50.16 for daily use. Do the rear tires touch the arch with normal daily driving on bumps with passengers?
Old Feb 24, 2020, 02:20 PM
  #610
Ulises Valdivia's Avatar
I’m having trouble on figuring out the right specs for my rims.
I currently have 17x8 +53mm rims. Will they fit on a 215/45/17 Tire?
GetterDragun
23
Jan 22, 2014 10:12 AM
ArmyMedic85
12
Jan 22, 2010 07:51 AM
funkad3llic
Nov 17, 2009 07:02 PM
AWD 20T
May 10, 2004 09:22 AM
gt40
Apr 28, 2004 09:49 AM
Quick Reply: Aggressive Wheels on 2004-2006 Lancer
