Aggressive Wheels on 2004-2006 Lancer
#63
Looking to possibly put some 5mm spacers on the car just to push them out a bit and make it look a bit better. I don't have enough money for new wheels until I can get my R6 sold.
#64
Whats the most agressive 16" wheel i could run? I'm on progress springs with 205/50/16 and would prefer not to roll the fenders
Also, how much work would it be to run a 16x8 +20?
#65
Are you on stock setup right now? If you are rocking stock wheels, go take a ruler, add approx 3.2 inches to your stock wheel and see how much more you'll be sticking out. From there you can gauge if you need to roll fenders or maybe pull fenders if you're unlucky
#66
Right now im on progress in just the front and im on work equip 16x7 +45.
BTW, are our rear hubs bigger than the front? I had an issue with a different set of wheels not wanting to fit on the back over the hub but the same rims would fit on the front.
#69
Omg 72.6? Yeah they clear but that's dangerous. U need hubcentric rings for those or you'll have problems eventually. U need 72.6 to 67.1 hub rings. Real cheap on ebay they are plastic. The wheels need to rest on the hub not the studs. As for front and rear maybe the rears had hub rings on them. It would really help with pics and testing the front wheels on the rears and rears on the front.
#70
#71
I've ordered a set of 17x7 +38 wheels and I'm planning on lowering the car with a set of coilovers in the next couple months so I'm wondering if I should go for 215/40 instead of 215/45 so that I won't have any rub issues?
