Aggressive Wheels on 2004-2006 Lancer
Old Aug 24, 2011, 01:54 PM
  #76
roblaza's Avatar
Originally Posted by Raikiri View Post
Yep. Xxr 527s
215/40/17 tiire good?
My setup is 17x7.5 +40 with 215/40/17's. No rubbing issues and the tires actually look small to me. So I'm thinking about going to a 45 series tire and getting spacers (3mm) and rolling my fenders. Or I might stay with the 40's and get bigger spacers...Im also on tein s-techs.
To conclude, yes, 215/40/17 is a good size...if you're lowered. If not for with te 45's.
roblaza is offline
Old Aug 24, 2011, 03:15 PM
  #77
Raikiri's Avatar
Lowered on coilovers at the moment
Raikiri is offline
Old Aug 24, 2011, 03:39 PM
  #78
roblaza's Avatar
Then I'd say stick with the 40 series unless you wanna lift it back up a bit
roblaza is offline
Old Aug 24, 2011, 05:30 PM
  #79
Vro0oom's Avatar
Thanks for the quick reply kelv, much appreciated!
Just ordered a set of 215/40/17 tires.
Vro0oom is offline
Old Aug 24, 2011, 05:59 PM
  #80
Roblaza is right, if you're gonna lower it, go with the 40 series.
k3lv is offline
Old Aug 24, 2011, 06:08 PM
  #81
Raikiri's Avatar
nice. i just placed the order today for my rims. cant wait to get the whole setup on the car and rollin
Raikiri is offline
Old Aug 25, 2011, 01:06 PM
  #82
RallyartRob's Avatar
Originally Posted by Vro0oom View Post
I've ordered a set of 17x7 +38 wheels and I'm planning on lowering the car with a set of coilovers in the next couple months so I'm wondering if I should go for 215/40 instead of 215/45 so that I won't have any rub issues?
hey regardless which wheel u go youll have rubbing, i have 215 40 17 tires pretty low on coilovers. and they rub when i turn and if i hit a big enough bump you will hear them scrap may be better off going 205 thats what i would do next time
RallyartRob is offline
Old Aug 25, 2011, 05:42 PM
  #83
roblaza's Avatar
depends on how low he wants to go...
roblaza is offline
Old Aug 27, 2011, 09:39 PM
  #84
Vro0oom's Avatar
I don't plan on lowering too much, I want to take my car to the local mountains and whistler for boarding so I don't want a snowplow.
Vro0oom is offline
Old Sep 14, 2011, 11:13 AM
  #85
Raikiri's Avatar
Originally Posted by k3lv View Post
You wont need a spacer. I ran 17x8 +43 fine before, no suspension rubbing. If you want more stance then grab a 3mm/5mm. Smallest you can find.
just about to go out and buy some spacers... do i need 2 or 4?
Raikiri is offline
Old Sep 14, 2011, 12:28 PM
  #86
CrAnSwIcK's Avatar
where is a good place to buy 5mm hubcentric spacers? I wouldn't mind some either, will 5mm spacers require longer wheel studs, or is it safe on stock studs?
CrAnSwIcK is offline
Old Sep 14, 2011, 02:53 PM
  #87
roblaza's Avatar
I believe you're good on oem lugs. And I can get some from a good friend of mine, but it means going to orillia to have the rims measured and the hubs measured lol
roblaza is offline
Old Sep 15, 2011, 12:38 PM
  #88
Hey if the wheels are same specs as Flips then I believe he only needed to spacers for the rear and they were 3mm. If you want you can check Flip's thread just to make sure.
nc_bboy is offline
Old Sep 15, 2011, 01:06 PM
  #89
Raikiri's Avatar
My wheels are 1/4in wider than his I believe
Raikiri is offline
Old Sep 16, 2011, 08:29 PM
  #90
I dont think you'll need extended bolts for 5mm spacer. Anything more then probably yes though.
The option of 2 or 4 is entirely up to you... it'll just slightly give a staggered look if you only get a set of 2. But since we are FWD it wont matter/effect the drivetrain.
k3lv is offline
Quick Reply: Aggressive Wheels on 2004-2006 Lancer
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
