Aggressive Wheels on 2004-2006 Lancer
#106
dunlop direzza sport z1 star spec...my friend has them on his Talon TSi, and his first time at the track with those on, he shredded his input shaft before the tires slipped...and i've been in his car while lapping and he was cornering at 90+mph and they didn't make a sound, he broke them loose on a hair pin, but man those tires are sticky...Nitto NT01's are supposed to be pretty good too...traction has a lot to do with your foot as well, ease onto the throttle, and feather when they break loose, if you floor it and go WOT through every gear you'll never stop spinning with that kind of power in FWD...i know AWD Talons with around that much power and they get wheel spin through 1st and 2nd with a 4k launch...
#107
to be honest i never went to track, i usually race in the streets ..
about traction and foot, i usually race from a roll..starting from 3rd gear..once i hit the pedal it
hits redline in a sec..which is really annoying..
and i never launched the car..
now i got confused earlier i was thinking of nt01 because its cheaper but they told me its crab!!!
something else the 235\40-18 will fit or not..???
#109
also i have only heard NT01's were good, i've never personally had any experience with them...the Dunlop's i can vouch for...
215 isn't much wider than 205, i'm guessing it would fit...the offset i'm not sure...but it depends on how low you go..
#110
215 will be good. Flip had 17x8 +35 I believe and need a spacer in the rear, rolled and a slight (very small) pull. So you might need a 3mm-5mm spacer in the rear. I have a set of 17x7.5 +45 rims but using hubcentric 20mm spacers I'll have it at 17x7.5 +25mm. How far the rim comes out and it measures the same distance with how Flips came out. So I think you'll be fine with the tires on that size rim. go to 1010tires.com They show how many mm the new set up will stick out from the current one. Also shows how much space you loss or gain on the inside.
#111
weird...well street racing is super illegal here, as in, you lose your car, your license, and up to a $10,000 fine...so yeah, i keep it at the track...if you're having traction issues from a 3rd gear roll then you need better tires. That's a lot of power for a small FWD car, and there's not really anything you can do about it other than easing the throttle.
still no one answered my question 18x8.5 +30 235/40 will it ever work..i need to get an answer on this please???? is it a dream or it can be done..?
#114
you will need spacers in the back because the rim i think would hit the lower control arm my 7 inch wides only just clear it but i guess it depend on the offset of the rim as well best way to find out is trial fit, spacer and pulling the rear quarters shouldnt be to hard if needed maybe even rolling would be ebtter
#116
With work it will fit but not just a simple fender pull will work ..... Look at this lancerhe has a 275 series 18" rim all around
http://www.youtube.com/watch?v=IfWlr...e_gdata_player
#119
ok planning on getting some xxr 527's 17''x 8.25'' +35. Ok question on if i need hubcentric rings because of the hub bore. also how would some 205/40/17's look and how bout rubbing. and spacers/rolling. i know raikiri bought some 527's just dont know how it went for him.
i found them on ebay i just dont know if i should get them
http://www.ebay.com/itm/17X8-25-XXR-...ht_3106wt_1034
also would like your input on color....f.black,gold or chromium black.
thanks.
thanks.
#120
http://www.ebay.com/itm/17X8-25-XXR-527-WHEELS-5X100-114-3-RIM-35MM-RSX-STI-/330665193231?pt=Motors_Car_Truck_Parts_Accessories &vxp=mtr&hash=item4cfd2e6f0f#ht_3106wt_1034
thanks.
thanks.
