Performance brakes
#32
our stock front stabilizer bar is pretty big, just replace the end links...plus it's a ***** to replace, you have to pull the subframe off, which includes lower control arms, steering rack tie rods etc...it's a big job. The rear bar will make a huge difference.
from what i could find the perches are only available with the progress bar from RRM, so i'm not sure where RRM gets the perches, or if they had them made...but i contacted them about only buying a perch kit cause i really would like the stronger perches, but don't want to spend over $250 on a rear sway bar, and they basically said "no", but if they did sell them separately they would be around $120, which is crazy...i'll just weld cross braces on the OEM perches...other than that, when you purchase the progress bar from any other source, the perches are not included from what i could find in my search, this eventually led to the purchase of the whiteline bar.
Hmoneybagz
37
Aug 28, 2014 08:46 PM
komilp13
17
Jun 20, 2013 12:46 PM
Trbospnkr
31
Nov 1, 2009 01:01 PM
dvd_mi
Jun 12, 2009 03:25 PM
