Caliper wiggle
Caliper wiggle
Okay, I am almost 1,000 miles on the brake rebuild job. All is good minus a sheared bolt holding a caliper. My question now is, does the caliper suppose to have a tiny bit of movement? The part in question is the rear piece that the slider pins hold onto the caliper. The caliper is tight to the mounting bracket, and has no movement there. I tightened everything per specs as much as I could. Thanks in advance!
Thanks for the replies. The bolt is still a mystery to me and my brother. All is good now, and have not had issues. The bolts were not showing sign of wear and tear.
TexasRS
73
May 30, 2005 04:37 PM
