-   04-06 Ralliart Tires/Wheels/Brakes/Suspension (https://www.evolutionm.net/forums/04-06-ralliart-tires-wheels-brakes-suspension-95/)
-   -   E-brake won't hold right away (https://www.evolutionm.net/forums/04-06-ralliart-tires-wheels-brakes-suspension/746136-e-brake-wont-hold-right-away.html)
cschubert444 Jan 19, 2018 06:56 AM
I have a 2005 Ralliart 5 speed that has some parking brake issues. When I park, the car rolls forward an inch or 2 before the parking brake holds. Also i have to pull the handle up to far. I have replaced the cables and the pads. I thought it has an auto adjuster that tightens the cables but i could be wrong. Any thoughts?
CrAnSwIcK Aug 29, 2018 09:21 AM
There are two adjustments to be made...one is the shoe adjustment which requires removal of the rear rotors, and then there is a turnbuckle of sorts right at the bottom of the ebrake lever where you can adjust cable tension...
Dan_evo_8 Mar 23, 2019 07:08 AM
I had this on my Evo 6 last week, adjusting the hadbrahan lever worked for me. But as said above failing that try the shoe adjustment behind the rear rotors!
