Spyder Projector Headlights
Any reviews or thoughts on these? I cant bring myself to spend the money on OEM ones and these look like a good option. Never heard of this company and am not sure on the build quality.
EDIT
Here is another page that has some more pics, I might have to give these a try.
2008-2011 Mitsubishi Lancer EVO X Halo LED DRL Projector Headlights
EDIT
Yea but do you think they are any good? Not just the build quality but the light pattern also. I did a quick search on the forums but could not find anyone that has them. Would be nice to know if they are even worth the money.
a member on 9g has them. they are china made but the light pattern is pretty good. For the lens i would keep an eye on because the stock ones tend to haze if not taken care of.
here the link
http://9glancers.com/index.php/topic,16632.0.html
he has the ones that were on your second link
here the link
Iv personally have heard bad things about the fitment of this companies headlights. I cant speak from experience since i have never purchased from them. But some say the clips dont line just perfectly and the projector lens can be kind king clouded.
Just got the lights in and did a test plug, of course the pins are a little too wide so it wont plug all the way in. Might need to do a little modification to get them to fit. I'll post some pics soon.
Dont mind the dirty car...
looks good so far. you should get some protector film for the new ones. they look too pretty to be messed up by road damage
install
I just recently got these headlights. Did you come up with a solution for the plug also idk if you had this problem but the original hid bulbs mine came with burned out within a week did you have this issue? also which wires did you connect you halos to and what method did you use? PM me or reply here thanks.
The DRL bypasses disable DRL permanently, but I would like to have the LED's on during the day and when turning on the lowbeams the LED's turn off...
halo wiring
I just got the exact same lights. everything works so far, but where did you wire your halos? I wanted to use the halos as my DRL instead of the projectors. Any thoughts?
