did an autox run tonight
and ran a best time of 70.19 understeering like a ****.
best time was a 60.64 which was an m3 with dunlop starspecs
wasn't really pleased with my performance, but i hope that wider tires will fix the understeer problem.
anyways to my question. has anyone taken their car to the track or autox'd it? and if so did you have a hard time steering? I know I had a hard time in the tight turns.
As long as you had fun, that's all that matters. I'm yet to take my RA to the track or an autox, but I have taken it on some fun twisties. I will say that the car does feel rather large, but I don't think it is as porky as it seems.
As for the understeer, that is something you have to be ready to live with if you buy a AWD or FWD car. I'm not sure that tires alone will fix your understeer "problem." Generally, a more rigid/thicker diameter rear sway bar will help with that. Stiffer suspension springs will help as well.
So I take it the car is bone stock? If so, you're lucky, because now you can start to measure the impact of each mod.
And how you drive it. The driver can cause more understeer just on how you approach the corner/entry.
Alignment specs? Tires? -- big factors too.
I think that Cusco actually makes some suspension parts like swaybars for the CY4A lancer that might be able to fit our cars. I am not sure what website I found it on but if you do a search o0n google you will find it.
I am just waiting for something that doesnt have JDM tax on it and waiting for months on end.
What year M3?
What was the average time of the other cars, an M3 isn't really in the same class.
If it's your first time doing autocross with that car, that's probably more a cause of the understeering than anything else. If you enter a corner too hot, it doesn't matter what kind of suspension or tires you have, the car won't turn. Stickier tires likely won't do anything either, the car will still understeer when driven at or past the limit. Understeering is the result of having more grip in the rear than in the front (that is, the front tires lose traction first). This is why a rear sway bar helps as do stiffer rear springs.
36 mile / 36 min warranty?
