Turbo Timer questions
Old Jul 7, 2010 | 01:34 PM
GRAPHITE RALLI's Avatar
Originally Posted by evo Tez
The newer models definitely do it themselves call the dealer and check for yourselves
i did...and its only the a/c fans pulling fresh air through the engine bay to keep is SLIGHTLY cooler....next time yours does it go put your hand next to the exhaust and im willing to bet thers nothing coming out of it...which means its not a turbo timer!!!
Old Jul 8, 2010 | 04:50 AM
Proteus_x15's Avatar
I asked the stealership and they said the same, only the fans stay on. Turbo timers keep the motor running.
Old Jul 8, 2010 | 06:01 AM
initial_d2k's Avatar
i havent start doing this ... but ppl with remote starter can use it as a turbo timer..
start the car with teh remote after u lock and shut off the car... it will run for few minutes.. then shut it out in distance?
Old Jul 8, 2010 | 10:27 PM
bacquerel's Avatar
^sort of like that but usually turbo timer has auto shut that's why it's a turbo timer so we don't have to wait for a few minutes and shut it out in distance, especially when parking at malls.
Old Jul 9, 2010 | 03:07 PM
Jake26's Avatar
turbo timer is a really great idea, i had it on my previous car, the reason for it is to cool the turbo off after beating on it. Most turbos are cooled by coolant and engine oil.. If you beat on the car and then come to a stop and just cut the car off, sometimes the fans may not kick in. Its always a good idea to keep the fluids moving there for next 30 seconds, you dont want anything to bake inside there..
as for the fan trick, this works even if you have driven lightly,, I came off an interstate today after my school temp outside 89F and i driven the past 15 miles at 65Mph straight up chillin, about 1/2 mile before my house i cut the ac on and left it on, doesnt matter one notch or full blast.. Came to a stop, and turned my car off, the fans stayed on... for next 3 min i believe..
november
17
Jan 11, 2021 06:03 AM
Jake26
Feb 23, 2011 03:02 PM
flevo8
11
Dec 20, 2006 06:15 AM
lilman8403
Feb 3, 2006 10:36 AM
Ryanmcd2
16
Aug 1, 2003 06:37 AM
