*Promising EVO Ralliart Style Lip for the RA made by JDP Engineering
#562
Not sure what you mean. The car is factory red with the cf lip installed. The only thing i painted was the front nose ring but it wasn't done when this shot was taken. Too bad that lip doesn't fit my X but I will most likely buy one for my X from jdp. The fitment and finish was top notch.
#563
So I have been contemplating picking up the fog light deletes as I had one of my fog lights shatter, and the stealership wants $350 for a new one. The only concerns I have is that since my lip is getting demolished from rock chips, my fog deletes will probably be just as bad. I honestly wouldnt recommend this lip to anyone that has lowered their car as it sticks out so far that you rub on any semi-steep incline. The clear coat is very weak and chips with tiny pebbles. Also, the fitment is so snug that it completely scratched the paint job under it so when it comes time to trash this lip, I will need to repaint my bumper....
#564
Oh and if there is someone in Alberta looking for one of these I will sell mine if you are ok with it having a small gash on it. The hole is on the bottom side of the lip so you cant see it unless you lay on the ground.
#565
