Stock turbo ralliart trap speed
So I went to the strip and cant figure why my time is on slow side but trap speed is high. I traped at 107.18 mph but time is 12.915 60ft was a 1.782 any ideas. also I think that speed might be a record on stock turbo
Nice run man. Considering your power (What mods do you have and what dyno did you get your numbers from?), you may be able to pull quicker but so much factors in especially your launch.
My best at the strip is a 13.07 @ 104 mph. It isnt too far off from you but most likely it has to do with elevation and also temperature. Where are you located and your not still in the heat wave are you? lol
1 Post
But still is that all ur mods in ur sig?!?!?!
But Im at only 90ft above sea level so it helps . Im not sure where Arlington Heights is so it may be that as well as E85 like you mentioned.
Current Mods
UR Down Pipe
DC Test pipe
DC CBE
Custom Intake Made by Devin@ Boostin Performance
Grimmspeed EBC 3port
1,000 Deatworks Injectors
Waldbro 255
UR upper and lower intercooler piping
Ams FMIC
Ams Small Battery
I Have ran a 12.854 @ 106.88 with a 1.859 60ft Before here is the weather from that run
Density Altitude: 1386 feet
Relative Density: 96.01 %
and last nights run was
Density Altitude: 1659 feet
Relative Density: 95.24 %
so any imput would be great
UR Down Pipe
DC Test pipe
DC CBE
Waldbro 255
Ams FMIC
Ams Small Battery
well went to the track tonight!!! and the car went 12.786@106mph on stock turbo with a 1.762 60ft. on stock suspenion and stock wheels and tires not to bad. evox swap soon to be done!!!
EvilDylan
Apr 25, 2005 07:39 PM
