Older Ralliarts: How are your cars holding up?
#32
1 Post
09 RA bought aug 2009
reg maint
@55k kms ACD pump replaced under warranty - no issues
@60k kms tuned with GST boost pill
@65k kms put on Magnaflow CBE
@95k kms upgraded to TBE(UR long DP/Metal HFC) with UR IC and all pipes
@98k kms replaced front 2x inner and 1x outer tie rod under extended warranty - no issues (1300$ even tho parts are $80ea its about 8h labour plus wheel alignment)
@100k kms 2nd ACD pump replaced under extended warranty - no issues (3500-4000$ about 2 years after frist pump replacement)
currently at 108k kms no issues
Note I live in Winnipeg, MB, Canada. Winters are -40C and about 6 mths long. I have had the odd starting issue but keep the fuel above 1/2 and maybe have the issue once or twice a year. I have the upgraded relays.
reg maint
#33
My 09 RA which just passed over 100,000 miles needs a new catalytic converter. Engine light code is P420. I believe the part is $950 and the labor will be $200. Son of a $*#%!
#37
reg maint
reg maint
The think you already got your money back based on the repair covered under extended warranty. Otherwise, it could've been a migraine for you.
#40
Bought her used at 36,000 miles, did complete service at 40,000 and again at 62,000 miles, other than a leaking front engine seal all is well.
Just changed out struts and went RRM grip springs and 63,000 miles currently.
Chris
Chris
#42
2009 Sportback
58,000 Km's
GReddy 33F intercooler
HKS intercooler piping
AEM CAI
CP-e turbo back
Custom tune with COBB 3 port
Not a single problem, pulls hard as **** with 285hp and 442nm atw
58,000 Km's
AEM CAI
CP-e turbo back
#44
Bought my 09 a year ago with 55K on it, completely stock and one owner. Currently has 65K on it, boost pill and GST pill-map. Did scheduled oil changes per the reminders with full synthetic, SSP steel trans filter gasket and new Ravenol DCT fluid, Dayco steel idler pulley swap (not the Hyundai ones). No leaks or any other issues. Just bought an ETS intercooler and pipes kit, can't wait to put them on!
#45
Hi guys! 2009 ralliart with 80k miles. So far, just a seized pulley at 65k and I had the timing chain replaced at 75k as preventative maintenance. Other than that, running solid! (Knock on wood)
I have an UR TBE, GST basemap V.3 and a boost pill.
