NEED HELP!! Clunking noise coming from rear end shortly after breaking
So recently I have been hearing this clunking noise coming from the rear end of my 09 ralliart. About a second after I come to a stop after breaking I get this clunking noise and can't figure out where or what the hell it is?? Has anyone experienced this or know what is causing it?? Thank you!
ive only owned the car for about 2 months now, I haven't changed it. the clunking just recently started, but it doesn't happen all the time id say 1 out 5 times after I come to a stop.
Ok. I would highly recommend replacing the fluid in the drivetrain. A quick search can give great results. A few members on here have awesome How-tos. I spend about 350$ for everything.
That's what I'm going to do. Change all the fluids out. I bought the diaqueen to do the diff and transfer case, what other fluids do I need? Do you remember off hand
*bump*
Problem solved
got all the fluids changed out and it was the rear diff. The fluid in there was never changed at 83 k and it was getting clunky. Lucky I changed it when I did because it could have had serious problems. I haven't owned the car that long or else I would have changed it earlier.
Problem solved
jdogstoll23
May 9, 2016 09:34 AM
powerman00
Jul 21, 2014 01:44 PM
DigitalN.
Nov 3, 2009 02:14 PM
