Cabin beeps when driving
Still sort of putting my new 2014 RA to the test. I've noticed that sometimes when I drive aggressively, the cabin will beep once like it's some sort of warning, but none of the lights or warnings show up on any screen. Does anybody know what this is?
I looked through the manual as thoroughly as I can, and there doesn't seem to be any mention of it.
Update
It beeped at me again today with no visible warnings when I was NOT driving aggressively. I was on the interstate slowing down to make a wide turn. I wasn't slamming on the brakes, or jerking the wheel or anything. It seems random and I don't know what the cause could be.
And the quote from the forum
It is part of the nav unit. The ding you hear is alerting you to a big curve ahead. I don't know if you can disable it. I haven't found it that annoying yet. I'm sure in the nav side of things you can alerts off
Hope that helps
Reading from this forum, could it be the Nav system? I don't know too much about the later models but check this out here - http://mitsubishiforum.com/forum/mit...y-roads-46307/
Something to do with curve guidance
Hope that helps
Hope that helps
