Can't See Backing up @ Night!!!
I have a sportback, and the reverse lights are terrible. I can't see a thing, and its even worse because its a hatchback. Are there better bulbs that will be brighter? Anyone have this problem?
does the ralliart have anything for a backup camera install the way the evo MR does? that would help
What do you mean? What does the MR have? I was hoping to keep it cheap
just get some bright ass LED bulbs...
Originally Posted by bradze
(Post 7624063)
I also have the same problem at night seeing while backing up but I think its cause I have 5% tint.:updown: |
WHo makes good LED bulbs?
I've noticed the same thing with my Sportback. Anyone have some info on replacing the stock back up bulbs with some bright LED's?
me too. someone advise on which bulbs please
The stock wing also hinders alot of the view.. Once i got rid of that and the headrests, i was surprised how much i could finally see behind :eek:
so that's why the reverse light is white....
Originally Posted by dxbtune
(Post 7633448)
If you need a site to get leds, First got to sylvania .com and get the buld type. Then use v-leds.com to get the bulbs. They have everything you would need to replace all of the bulbs with leds on the car it you wanted to.
Christ that site has so many bulbs to choose from. Pretty confusing really.
I put these in. They were cheap from autobulbsdirect.co.uk
The bulb is the same size as OEM. The filament looks a bit bigger, but no noticeable difference in light levels. Ive heard that LEDS are brighter but dont cast as much light as a filament bulb so I dont think they are the answer IMHO. R921 12V 21W Capless W2.1X9.5d Stop ( High Level Brake Light ) |
| All times are GMT -7. The time now is 02:22 PM. |
