RA Concern List!
So I just bought my new RA 2011 and these are the concerns that I have (1000K).
1. SST transmission life. I can hear the transmission is forcing too much. Would it last? How many 50K RA are out there with no problems. 2. Brake disk are already scratched (not smooth), worst on the rear. 3. Tail pipe already has burned oil tips. too much gas vs. combustion 4. Idle revolution unsteadiness (Cold start) I test/drove 4 used RA before buying this one and all had the same problems. Are they any recalls for 2,3,and 4? Or what did you do to make it better? |
IMO:
1- Wait and see 2- Change Disc and Pad? 3- Get a tune (btw, burned tip = black or .. superduper burn titaniu m :D) 4- Deal with it... |
initial d2K- These are some serious concerns. Stop launching.
Originally Posted by pendejo
(Post 9345592)
Are you talking to yourself when u wrote "Stop launching"? |
1. There are Borg Warner twin clutch transmissions with over 100k miles on them, and the original clutch packs, as they have been on the market from the old TT's for a long time, over here and even longer in Europe. Just like any part that sees wear, it's all about maintenance and abuse (and yes, modding = abuse). There are many GTIs and Jetta GLIs with well over 100k miles now as well, and every single one of those had gear whine from the start and much harsher shifting (when doing a 2->1 downshift) than the TC-SST.
2. Foreign material can score your rotors. This is not an RA-specific thing that can happen. 3. Everything nowadays runs rich for safety. My 08 GTI with the FSI motor put copious amounts of soot from running rich onto the tail pipes -- at least it hoses off on the RA. As mentioned, get a tune if you really want or just live with it. 4. Ya, I don't disagree that the revs bounce a bit, not just from a cold start (happens in traffic). It's not crippling and not concerning to me. The real issue is people, and not just you OP, buying a car with bleeding edge tech and expecting a hiccup free experience like buying a vanilla civic when you're buying a tech showcase car that basically guarantees potential idiosyncrasies. I've come from the world of Euro vehicles where everything is basically a crapbucket, it may have a nice interior and solid build quality, but the gremlins in the electronics and mechanicals will drive you nuts. |
Other than the breaks, none of what u mentioned are "problems". Just the car. My car, friends cars all do the same.
The car will last u a long time. Just takle car of her and she will take care of you.
(Post 9345518)
(Post 9345592)
1). I know several people who race their Ralliarts and have well over 50K on the transmission. The original fears were unfounded. 2). I make a Big Brake Upgrade that fixes that problem. It allows for a much beefier rotor to prevent fade and premature wear. 3). These cars don't come pig-rich from the factory, if that is what you are insinuating. If you would like a FREE custom tune, check out the GST Basemap thread and buy a boost pill upgrade. 4). Welcome to Mitsubishi. You can try the custom Basemap, to see if that helps. You can also have Urethane inserts installed in your front motor mount to help with the transmission and motor rock in first gear. Other than that, this is normal. |
(Post 9345592)
I do have to wounder though if you test drove 4 ralliarts, and all gave you the same 4 concerns... why didn't you ask your question before you purchased one? |
(Post 9345518)
(Post 9345518)
(Post 9345518)
(Post 9345518)
(Post 9345518)
(Post 9345518)
(Post 9345518)
Before I bought the car I test drove two 2008 RA and a beat up 2009. All had the similar problem listed above. I thought by buying a new one the problem was going to be solve, but not. These are some serious concerns.
(Post 9358561)
How are these serious concerns? Did you not read all the feedback that everyone gave you? These are not issues, this is just par for the course. Rotors and pads wear down on every car. In its stock form, the car runs rich. This is why you are seeing unburnt fuel on the exhaust tips. Of the too extremes, running rich is preferred. Almost all forced induction cars will have this. You can check the fuel relays to make sure you are running the proper ones and it may fix this issue if you are seeing it.
Your car is fine. Just wait for the absurd tranny noises later on in the RA's life. If you're worried now, you'll be panicking later!
It gotta reiterate what has already been stated;
If These are some serious concerns. -End Coddle- |
Hi, and welcome to the interesting world of RA ownership! :)
I was in exactly the same boat as you when I first got my vehicle. I went back to the dealer three times in the first month, worried about the turbocharger whine, the brakes, the cooling fans, etc. etc. So yeah, I'm a closet stress-head about such stuff. Don't tell anyone. ;) The thing is, this vehicle's engine/drivetrain is not your average "tuned up for sporty version" style. Mitsubishi took an engine, transmission and AWD system from their high-performance Evo model and built it into a Lancer. You know all this, but it's worth saying... - The engine is a rough, noisy pig when idling cold, when driven cold, when driven off-boost, etc. Its reason for being is going wide-open-throttle - and that's where it shines. - The transmission clanks, clunks, whizzes and whines. Its reason for being is to deliver shifts that take 0.4 seconds, while allowing the throttle to remain wide-open. Again, it's all about the hard driving. When you start flipping through the gears on a spirited drive, it's in its element. - The AWD drivetrain also whines and clunks. It's there so you can use the above two awesome (but noisy) items at full-noise on wet roads without losing traction.... and it does its job well. To your specific issues...
(Post 9345518)
To make it last a long time, change the SST fluid and filter after 10,000km (or insert whatever you can afford here - it's expensive) to remove the wear-in stuff.
(Post 9345518)
Also, be aware that rear brakes do very little work. They will take a long time to wear in compared to the front pads/rotors.
(Post 9345518)
(Post 9345518)
To make it last, don't thrash it when cold. Drive it lightly until engine, trans, diffs, tyres are warm - then drive it hard. Finally, if you're stressed about it, rely on the warranty. You'll have a good warranty from new. Modding the car with reflashes, boost pills, etc. may not be for you. If you modify the RA, you can unlock its hidden performance benefits. But if a denied warranty claim for a $10,000 SST replacement will destroy you financially (or psychologically), don't go down that road in the first place. Now go enjoy the new car! Rich |
