Installed: Mud Flaps on Sportback
So i bought the ones for lancer, put them on the sportback, look good, very strudy. The only problem was hole #3 on the back, i popped a hole in the black wheel well plastic, and put a screw and washer in there.....would of been easier with the tire off, but who cares. tell me what you think. And is this a first for sportbacks? (idk how to insert photos so work with me)
http://s726.photobucket.com/albums/ww266/AnthonyB112595/mud%20flaps/http://s726.photobucket.com/albums/w...5/mud%20flaps/ |
Just a heads-up, this probably should've been posted in the "Show and Shine" section
Originally Posted by omegis
(Post 9415401)
i like the red n white contrast
Looks good!
thanks, i noticed that since i couldn't use the spacers the flaps bend in the back more than the front.
The spacers go in the front.... i am confused. Mine fit fine...
Originally Posted by Veronica
(Post 9474274)
Nice!!! I want these too. But I went to the Rally Armor website and see that the Lancer mud flaps they have specifically say "*Does not directly fit 2009+ Lancer SPORTBACK or Lancer SPORTBACK Ralliart*". Am I looking in the wrong place?
The red look bad, just sayin. Other than that they look really good on the SB
Originally Posted by FASTER345
(Post 9524558)
And to the OP dont listen to the haters, the red looks good. Its different. |
Drill through the the rear mudflap that doesn't have a hole to line up to an existing hole (like the other two holes do) .
Insert the provided screw and secure from the backside of the plastic inner fender well with the supplied nutclip (just hold it - i won't 'clip to anything). |
DaJackson and Veronica, thanks for the info! Did you get the $47 regular or the $124 urethane versions? I don't intend to go a-rallying, just want to keep road grime off the sides of the car, seems like regular would do it. What do you think? Thanks again.
Cheers. |
I went Urethane just because I like the look and the lettering. I think they are longer too, but choose whichever you like best.
Originally Posted by aaronk
(Post 9524654)
