Does the RA have a simpler version of the Evo X's AWD?
Or is it a completely different system altogether? I've read online that it was lifted from the Evo IX but couldn't find anything to back up forum talk...
^true. there is confusion due to early press releases saying 'EVO IX components'
AFAIK it is a RA-specific part and 'simpler' (cheaper) than the EVO X unit. |
front differential and transfer case are exact same as the evo x mr. The rear differential is something else. The ralliart rear is a mechanical limited slip diff while the evo has active yaw control diff.
Good to know. Thank you both.
Wonder how hard it would be to install an Evo X diff in the RA.
it has evo 9 awd components.
Transmission is same as MR except for gear ratios. Transfer case is same as MR with ACD and all.
Rear diff is *like* the USDM Evo 8/9 because it does not have AYC like the Evo 10 Therefore it doesn't have "SAWC". However it is a different physical unit then the Evo 8/9. This also makes it stronger than the Evo 10. |
Originally Posted by deprydation
(Post 10517454)
Originally Posted by NFSLancerRA
(Post 10520055)
People go to great lengths to get rid of the Evo X diff...:rolleyes:
Bumpity bump bump.
What are the issues with Evo X rear diff? Just wondering :) |
Originally Posted by TrailBrake
(Post 10550206)
Bumpity bump bump.
Originally Posted by gaabbee
(Post 10550338)
Pretty sure they can't handle a lot of power. Also from reviews they are not very good in a slalom course
Completely anecdotal, but my previous car had in it's final model years a very early implementation of an electronic rear limited-slip differential (0-100%). Lockup wasn't as smooth and predictable as the completely mechanical LSD found in older models, so it was often 'downgraded' to the older model's setup. Sometimes simpler is better ;) |
simpler is ALWAYS better.
| All times are GMT -7. The time now is 01:50 PM. |
