What's the difference between the '09 and '10?
What's the difference between the 09 and 10 Ralliart. Did they make any changes from one year to another.
ive been in an 09 before , and i own a 2010 . as far as i can tell the only changes are minor . such as the 09 has an dash LCD that is all red. and the 2010 has a full color dash LCD. and i thinks some switches are moved around . as far as the engine drivetrain. the SST has been the same from day 1 . so its still a ticking time bomb. they have the same 4b11t.except the evo has a slightly better turbo. but the 2010 needs NGK iridiums i believe mine are ILKR7E6's. which are 15 each. my local parts stores have the 09 listed with different options for plugs so they might be different unless the shop messed up. but nothing major
No major mechanical changes to the engine, SST, body, suspension, or anything like that.
For 2010 some small cosmetic changes such as smaller antenna, color info display, lids for the cupholder area and lower storage cubbies, and the color of the dash trim piece changed a little bit. |
As far as I can tell outside of cosmetics (LCD/wheels/colours) there hasn't been any changes to the Ralliart since the 09 model
^At one point (2011?) the TC-SST went from two drain holes to three drain holes...
Veronica, you got that backwards 3 to 2 :)
D'oh! ><
I stand corrected. |
I know that in 2010 the upgrade package (Recaro's, GPS, sport pedals and moon roof) was an option, where as 2009 those came standard. The headlights were a big kick in the pants for me. 2009 came standard projectors with HID's where as my 2010 has sealed beam halogens. Mine came standard with the Ralliart floor mats.
| All times are GMT -7. The time now is 12:35 AM. |
