-   09+ Lancer Ralliart General (https://www.evolutionm.net/forums/09-lancer-ralliart-general-266/)
-   -   2013 ralliart won't start (https://www.evolutionm.net/forums/09-lancer-ralliart-general/765305-2013-ralliart-wont-start.html)
blurally13 Jul 30, 2023 12:56 AM
So I got a audi q3 2022 sline at the beginning of the year I need a bigger family car I left the ralliart over the weekend I picked it up on Tuesday I worked couldn't make in to pick it up on Monday they had it on the back lot well secured I picked it drove fine started up fine no issues let it warm up had about 3 qtrs of a tank got home parked it I knew the car was going to be parked for a couple weeks so I made sure it was on a leveled surface discontinued the battery didn't want it to die just bought it last year in September I decided one day I was going to take it 2 work connected the battery made sure it was healthy turned the key n it started to click n out of no where no start turn the key back gave it a minute turn the key on waited for the pump to Humm I thought I was hearing it or I think I hear but when I turn the key tick tick tick nothing spark plugs just got replaced had a fusible link replaced relays n fuses check n replaced anyone with any ideas or suggestions b4 I give up n sell
DRAGHICI Jul 30, 2023 07:33 PM
I'm sorry to hear about the trouble you're having with your Audi Q3. It can be frustrating when a car doesn't start, especially when you've recently purchased it. Let's see if we can figure out what might be causing the issue.
Since you mentioned that the car was parked for a couple of weeks, it's possible that the fuel system could be causing the problem. Check to make sure you have enough fuel in the tank and that the fuel filter isn't clogged. You can also try priming the fuel pump by turning the key to the "on" position for a few seconds before starting the engine.
Another possibility is a problem with the starter motor. Sometimes, a clicking sound when you turn the key can indicate an issue with the starter. It might be a good idea to have a professional mechanic take a look at it and test the starter motor.
Also, check for any loose connections in the electrical system. Make sure the battery terminals and ground connections are secure and free from corrosion.
If you've tried these steps and are still having trouble, it's best to consult a qualified mechanic or take the car to an authorized Audi service center. They have the expertise and tools to diagnose and fix the problem.
Before considering selling the car, it's worth exploring all possible solutions. There may be a fixable issue causing the starting problem. Hang in there, and hopefully, you'll have your Audi Q3 up and running smoothly again soon!
