RRM Springs.
#377
I love the look of mine. No more noise when turning, that's good. That went away by itself after a week of driving.
BUT my cd player skips like crazy on street roads. It's really not very usable anymore, except on the freeway.
Anyone else have this issue?
#381
I'm running 245's on x8.5 +30 fitment, which is basically the same as above if you work it out. Only a good solid roll in the rear and I don't rub anywhere.
8.5" to 9" = 1/2" wider = 1/4" (or ~6.5mm) further out on each side
+30 to +36 = 6mm more recessed
So, in theory, you'd poke approx. 0.5mm more than my setup. I think you'll be ok with a 245/40/18
#382
Wow crazy. +30 and not an issue? Thanks for the feed back! It's only the rears that need to be rolled right? How much rolling should I tell them to get done?
#384
Sight, I just saw someone selling wedssport SA55m with specs
5x114.3 Center bore is 73mm.. Fronts offset 36mm, rears offset 20mm.. All rims are18x9 all around. Would these fit an RA after rolling? =S
#385
I need help!!!!
Im ignorant at this alignment thing. I have the the rrm grips.. And also i just changed to new tires..
225/45/18 35offset...
My other ones wore the f out from the insideee! I had an alignment check yesterday.. I was going to align my ralliart and one of the mechanics told me " u need a camber kit when u lower the " n that i had to adjust the cambers or w.e.... On yesterdays reading my ride was:
my fromt camber is (left)-0.4 n (right)-0.7 normal range of -0.6 to 0.4
The rear ones are way off tho.. (left)-2.1 n (right)-1.8 ...normal range of -0.4 to -1.4..
Toe is all messed up (this can be fix with the alignment tho)
what specs should i use on the toe..? Im a daily driver. Please advise.. Also
Do U think i should get the camber kit for the rear or just get an alignment to fix the toe... ?
Thank u
Thank u
