Help me choose wheel size!!!
#33
+1 very true. I'd go 235s with an 8" wide wheel.
#34
Bro I hate to say it but that 235 on a 9.5 is not that strech at all. You can even run a 225 40 if you wanted to and that's strech. There is a lot of cars out there in the track with 9.5 wheels with 235 40 or even 235 35 wheels and they are doing fine. It won't affect your performance at all. This is called a semi aggressive set up. With the offset that you ordered you should be more than fine but you should be prepared to do the work to make them fit. The most camber you should run is a -1 or -1.5 with that offset, maybe -2 which is fine and is nowhere near extreme. CHeck this thread out and research your set up:
https://www.evolutionm.net/forums/ev...o-x-style.html
The look is not for everyone so keep that in mine that not everyone will like it but at the end of the day you are the one driving your car, not everyone else.
#42
Not always bro. If you are looking to have an aggressive set up then a lot of people put wide rims with strech tires. The tire doesn't always have to be as wide as the rims. Drift cars dont and some track dont also. It all depends on what you like.
#44
If you want to do this for looks, go for it, it does look pretty cool but from a performance standpoint it does seem like a waste of time, money and a car.
#45
Drift people are in a league of their own but I've never heard of professionals intentionally running super skinny tires on wide rims. As indicated above, skinny tires on wide rims actually reduces traction because of the way the tire sits (too flat). Pros have enough power and skill that they can run a proper sized tire.
BTW, I am talking about good drifters. Bad drifters need all the help they can get just to break traction.
