Eibach Springs Are Available
I just ordered the eibach springs and turns out that the springs are for the regular Lancers...
I should of researched a lil more... the part number is 6048.140
I did know until I bought the springs...
Should I just cancel the order?...
I called Eibach today the springs are ready and in stock. I Ordered the Rallairt Pro Kit I should have them by Wednesday of next and installing on the Weekend. Will Post Pics...
Can't order directly from Eibach have to use one of the links to online or local store.
Eibach Part No. is 6050.140
This is the part number I was referring to. The part number he wrote is the right one for the ralliart. I'm gonna call them today and see if I can change to the ralliart springs
Yes, but let them settle in for a week or close to 100 miles then get it aligned. The Tech I spoke with from Eibach told me getting a standard Alignment after the springs settle in is good cause if you go with a more aggressive alignment you just be changing tires more often.
I just called AJUSA.com and they confirmed that they don't have springs specifically made for the ralliart. The ones try have are for the regular lancers.
Where did u order yours ralliart2009??
Depends who you get as a sale person some if they don't see it inventory they don't bother to help any futher than that. I called two other places that did not have it in inventoy only the set for the regualr lancers, before I called AJUSA and the Rep I got hooked it up. Ask the sale person to get it dropped shipped to your house.
Bro, Read my previous post (AJUSA.COM) they don't have it in stock cause it a "NEW ITEM" just release by Eibach. The Sale person who helped me went the extra mile took down my number. Called Eibach with the part number I provided. He called me back about half hour later and told me he can get it for me but it will be shipped directly from Eibach cause they do not have it in inventory yet and will not get it in inventory until after the holidays mid first QT of 2010. I gave him my info and payment he took care of the rest.
Any idea why the Eibach site shows part number 6052.140, not 6050.140 for the ralliart?
EDIT: Actually it shows two different part numbers for the Ralliart. Wonder what the difference is?
EDIT 2: Looks like the 6052.140 is for the Sportback Ralliart only, and the 6050.140 is for the sedan and sportback ralliart both. Will have to call and ask what the difference is.
Part number 6052.140 supersedes to 6050.140. I guess when they originally started developing these springs they made a new part number for the Sportback but the 6050.140 worked for both.
That is Faults i called and talk to eibach the way back when i got my RA and the RA pro kit and sportline are different then the Lancer GTS
RA spring rate is higher
also the RA pro kit and RA sportback Pro kit are different kits as well
RA sportback pro kit has a stiffer spring in the rear
the car is a bit heavier then the RA
RA pro kit part#6050.140
RA Sportback Pro kit Part#6052.140
they dont supercede each other untill other ways stated by Eibach
