Brembo Front BBK
Ah, so the BBK debate returns. Already been half-beat to death...
I'll save Amby the trouble of explaining it again. See here: https://www.evolutionm.net/forums/09...alliart-2.html
If your rotors are glowing red, then perhaps a BBK is worthwhile for you. Otherwise you can get the same braking power with some good rotors and pads.
yes and larger rotors give you a larger moment. i.e. like a larger lever arm. Why do bigger brakes exsist then hmmmm ? Hydraulic pressure for most braking systems is dependent on the ccs of the piston cavity and the piston dia itself. The two factors that play into braking distance are three items contact patch, pad area and rotor dia. This also has to do with less force needed to exert full braking force, i.e. why new car manufacturers have embraced brake assist. Generally yes BBKs are mainly for better modulation and fade prevention but if your factory brakes are junk like the stock lancer 60-0 in 164ft and the evo x in 117ft and it even weighs more...... I don't we are talking about the same set of circumstances here.
yes agreed but if you have substantial fade you will have longer stopping distances.
You're arguing against established brake knowledge and physics. Pad area has no effect on stopping distance, nor does rotor diameter. You are welcome to the research yourself, but suffice to say you are wrong.
Real world showing what I'm saying
http://www.zeckhausen.com/Testing_Brakes.htm
http://www.modified.com/roadtests/07...est/index.html
Good FAQ that discusses the physics behind brakes
http://www.ffcobra.com/FAQ/brakes3.html
Nice quote from that FAQ
Regardless of your huge rotor diameter, brake pedal ratio, magic brake pad material, or number of pistons in your calipers, your maximum deceleration is limited every time by the tire to road interface.
Your hydraulic pressure should be the same with a BBK unless you're upgrading other braking components further up the line (like master cylinder).
Bigger pads won't help unless you have more piston pressure to keep the pressure-per-square-unit consistent. If you take a car and throw on some pads that are 2x the area, the pressure between the pads and rotors will be LESS per square-unit than the smaller pads, unless you can increase the fluid pressure in proportion to the increase in pad size.
From a physics "lever" standpoint, you are correct in that rotor diameter plays a part, though the radius of a BBK rotor isn't a huge difference from the stock rotor. Also keep in mind with a larger, heavier rotor, you now have more rotational inertia to try to stop (just like heavier, larger diameter wheels)
Do you experience brake fade after a single stop? Unless you're driving a 1984 Lada I doubt you'll experience brake fade while performing a single panic stop. That is what we are discussing here. If you're racing, brake fade is a legitimate concern but that is a cooling issue, not a brake force issue.
I get all the heat transfer business. And the modulation business and even the pad material and area business but as a package when driven aggressively as I do in a heavy AWD machine bigger brakes will stop you quicker. Or maybe I have been eating crazy pills.
