Wilwood Superlite BBK for Ralliart with EvoX Rotors.
#46
#48
Uhm im In toronto. Unless Calgary is now somehow part of Russia.................
email Brian at sales@fastbrakes.com make sure you ask for teh Evo10 rotor option.
I think they have two kits in place, evo9 and evoX rotors. Evo9 brakes will fit under 17" rims. Clearly the evoX ones will not.
NEWB
NEWB
#49
Ok so my mistake. This kit uses the evo9 rotor. Since I asked for it to fit under the 17" rim...... FML. They are asking if there is enough interest to make a kit that will fit the evoX rotor. Since these wilwood calipers only clear brakes up to 13" in size the next step up caliper is $$$$. However u will outbreak an Evo any day.
#53
The calipers in my post will only clear rotors up to 13" in size maximum hence why they use the evo9 rotor. (Superlite)
The bigger calipers (w6a model) will clear evoX rotors but they come with 6 piston design only and will not clear 17" rims.
My apologies for the confusion.
Best to speak with fastbrakes directly for specific info.
#54
Ok sorry. Both calipers have the same piston size area as factory Ralliart brakes.
Biggest question is what is the price difference?!
#58
#59
Do you have one of those places near you that can perform brake system tests? I have one that can do a full test and summary, including front/rear bias. I'm keen to see how the IX and X rotor styles stack up for bias, when the rest of the RA braking system is left stock.
Rich
Rich
