Wilwood Superlite BBK for Ralliart with EvoX Rotors. - Page 7 - EvolutionM - Mitsubishi Lancer and Lancer Evolution Community
Thread Tools Search this Thread
Old Jun 30, 2015, 12:38 AM   #91
Drives: 2012 Ralliart Sportback 298 whp
Quote:
Originally Posted by Drew314 View Post
Are you talking about pictures from the X rear install how-to I posted? All of the pictures I posted there are still up. If you need any input, PM me.
BUT.....
I would not be so certain the X rear setup will work well with the Wilwood kit in this thread. Not to beat a dead horse, but those Wilwood calipers are small, and have a very small pad contact area. I'm not sure which Wilwood calipers these use (what piston size, because they have a few options) but you could shift brake bias too far rearward. I would give Fastbrake a call to see what piston diameter these calipers have.
Thanks for the answer, Drew.
Yes, I was talking about those pictures, but I understand what happened. I've been accessing through my company's PC, which probably blocks the websites where the pics are hosted. Once I disembark from the rig I'm on, I'll check the thread again and maybe call fastbrakes to see the pistons sizes and etc.
I have actually already bought this kit, and installed just a week before coming to work. So far, so good! I could really feel a change, specially fading wise.
Is it the best bbk for the car? Course not, but considering that the shipping to Brazil of any BBK is huge, and that our government is ****ing with our currency, it was either this or nothing.
Maybe the best brake changes on the rear for this kit, bias wise, is just changing rotors, pads and lines then. I'm still on stock rear rotors and lines, but I'm on HAWK HPS pads.
One question I have about this kit, that I'm not sure if anybody could help (don't know if there is many people using it nowadays) is regarding the ferodo pads x rotors. These pads are HUGE and THICK. I hear a strong whistle every time I break on medium going to low speed. A friend of mine told me his rotors lasted only for 2 MONTHS!! The shop he took the car to told him it was due to these much aggressive pads.
Anyone have any experience on that?
Thank you all!
Offline
Old Aug 18, 2015, 08:32 AM   #92
Drives: 09 ralliart
wildwood bbk
I'm interested in a set for my 09 ralliart where can I buy them ????
Offline
Old Aug 18, 2015, 01:29 PM   #93
Nast_Nas's Avatar
Drives: 2013 Lancer Ralliart, 2013 Outlander Sport SE
Quote:
Here you go! http://www.fastbrakes.com/category_s/207.htm
Offline
Old Aug 19, 2015, 06:53 AM   #94
Hey guys, like promised before, here's some update about this kit performance on the track: I really enjoyed it! I didn't compare it with the stock brakes on the track because I didn't have the ***** to take the car to race with stock brakes, as they would fade on the street after some spirit driving.
But this wilwood did its job. After 3 batteries of 45 min each, it never fade, and it braked greatly. Obviously it's not the same as having brembo 6 pot on the front and 4 pot on the rear, but it's still balanced, as I didn't notice any rear/front sliding when braking (all I have on the rear is the hawk hps pads).
However, I took it yesterday to a shop here to have it taken a look before going to the track again this Saturday. They've noticed that one of the calipers is not fully aligned with the rotor. You can see the pistons from one side way more off the caliper than the pistons on the other side of this caliper. I've been told that the brackets will have to be changed, to make this alignment perfect. Their concern is that the piston that gets a little off could move away from the sealing area and the brake fluid could start leaking. This could happen when the pads wears out some more.
I'm having iron brackets made, instead of this aluminum that comes with it, and hopefully correct this misalignment. Maybe I'll change the pads too, as my friend noticed too much wear on his rotors with the ferodo pads. We'll see.
Keep you posted!
Offline
Old Aug 19, 2015, 04:10 PM   #95
Nast_Nas's Avatar
I see they make a 6 piston kit now that fits evo x rotors. http://www.fastbrakes.com/category_s/207.htm
Offline
Old Aug 20, 2015, 11:26 AM   #96
It seems to be worth the price, but it raises 2 questions IMO:
1) In the description it says costumer supplies the rotors. Does that mean that rotors are not included in the 6 pot kit?
2) It will shift the bias forward.. You might wanna think about getting a rear kit if getting this one.
Offline
Old Aug 20, 2015, 11:57 AM   #97
Drew314's Avatar
Drives: 2009 WW Ralliart
For the first question, that is correct in that they do not come with rotors.
As far as shifting the bias forward, it actually shouldn't shift it forward much at all, even with the 6 piston calipers. If FB has done their homework (I would assume they have), then they would have selected an appropriately sized Wilwood caliper with the correct piston area. Honestly, the biggest drawback with both kits, 4 piston and 6 piston, is the pad contact area. They are very small. Even the 6 piston pads (which are the same exact pads used in the 4 piston kit) are a descent amount smaller than OEM X 4 piston Brembos. You will gain rotor diameter (increasing the moment arm), but have about the same pad contact area as a stock RA pad.
Offline
Old Aug 21, 2015, 03:53 PM   #98
Thanks, Drew.
It seems to me, then, that choosing the 6 pot over the 4 pot would be good only for being able to use a larger rotor, increasing the moment arm.
Very good, thanks!
Offline
Old Jul 13, 2017, 05:26 PM   #99
c08
Just curious, does anyone who has/had one of these kits know what size spacers are needed to clear the OEM wheels? I saw someone used 25mm spacers but not sure if something smaller would work.
Offline
Thread Thread Starter Forum Replies Last Post
Ralliart/GTS Lancer Big Brake List [ BBK ] neogeo64 09+ Ralliart Brakes/Wheels/Suspension 9 Nov 10, 2017 04:27 PM
Ralliart Turbo set up TEXAS TRAVISTY Outlander Sport 56 Aug 9, 2017 11:31 PM
Has anybody used these rotors/pads? eeevooo Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack 13 Jun 21, 2017 11:59 AM
FS[Mid-Atlantic]: OEM EvoX and Tactrix Cable bhaikalis For Sale - Engine / Drivetrain / Power 5 Feb 27, 2017 05:11 AM
Black Fuel Pump Relay - Dead One Cut Open - Pics Mike W Evo X Engine Management / Tuning Forums 84 Aug 19, 2016 09:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
