$38 and $55 Adj Rear End link Options
$38 Adjustable Rear End link set
Blox [BXSS-10101-AEL]
M10 x1.5 Jam Nut (x6) $2.50
M10 x1.5 Hard Hex Nut (x2) $1.00
Use all the hardware from the Blox kit and add 3 Jam & 1 Hex Nuts to each Endlink shown in the layout below.
$55 Adjustable Rear Endlink set (racingline style)
Energy Susp End link Grommets [9.8106G]
M10 x1.5 x75 Bolt (x4) $6.00
10mm Washer (x4) $1.00
M10 x1.5 Jam Nut (x4) $1.60
Use only the Hiem Joints and Locking Nuts from the Blox kit and 4 grommets , 2 bolts, and two washers to each Endlink shown in the layout below.
Links are on the first post . The hardware (bolts / nuts) can be picked up at local hardware store.
I believe the rear sway bar is a little different on the GTS but they should work if your stock sway links are 3-3.5"
Nik128
30
Apr 30, 2014 04:59 AM
