Rear Camber Adjustment - 2009 RA
Just checking through the treads & didn't find my answer. I was told today, you cannot adjust the rear camber on our cars, is this true?
I just bought new summer tires, got an alignment, and the LR= -1.5 (Technically off spec, in the red) and the RR =-1.2 In the green, but not perfect.
If its possible to adjust, can you please post a pic of the bolt for adjustment? and a brief description of the location & connections.
Thanks.
Thanks.
You have 3 options to camber adjustment in the rear.
1. Rear Whiteline bushing replacement. (requires a shop to press in new bushings that offset the mounting hole for the rear lower arm)
2. Upper adjustable replacement arms from (Megan, Hardrace, etc)
3. Lower adjustable arms. (Hardrace)
dipsetinallday
11
Apr 28, 2016 06:02 AM
mitsuevodriver
19
Jan 17, 2016 08:37 AM
turbotime
Jul 22, 2011 09:58 PM
Canada_Comp
Aug 5, 2008 12:13 AM
