What's our ABS pump model no.?
Hello guys!
I have the ABS ASC lights problem on my 2009 Lancer Ralliart so I had a check from local Mitsu dealer and they told me that the pump is broken and that the previous owner replaced that pump with the wrong one. The one I have is 4670A352 while they told me that the right one is the 4670A353 or 4670A888 (the newer version).
Maybe you can do me a favor and check what it's installed on your car, I'm getting a little confused O.o
(p.s. a used part seller told me that the 4670A265 is compatible with the 4670A353... now I'm getting more confused than before )
ok so.. I made some research and found that the original part number is 4670A353 but the visual part number (the one written on the ABS pump) is 4670A352.
So I searched on goole images for some Lancer Ralliart high resolution engine compartment pictures and I found 3-4 images with visible number on the pump and it is 4670A352!
Can I ask you to please take a look and tell me what you have?
If 4670A352 it's confirmed then I'll have to explain to the dealer that this part it's fine for my car! I already have a used 4670A352, while they told me that a new pump cost about € 2000!
thatmr2guy
234
Jan 25, 2019 08:04 PM
J!n K@z@mA
21
Nov 2, 2012 11:57 PM
kikiturbo
Jun 27, 2012 06:14 PM
