-   09+ Ralliart Brakes/Wheels/Suspension (https://www.evolutionm.net/forums/09-ralliart-brakes-wheels-suspension-310/)
-   -   coilovers and edfc's (https://www.evolutionm.net/forums/09-ralliart-brakes-wheels-suspension/513637-coilovers-edfcs.html)
robyn402 Sep 10, 2010 08:41 AM
looking for options for coilovers that are compatable with some sort of electronic damper controller but having no luck, any help is appriciated
initial_d2k Sep 10, 2010 09:12 AM
Cusco
Tein Flex
evil03 Sep 10, 2010 09:37 AM
there no point real point for the controller... every one i know that have it used it like 3 time and its just there...
im on coilovers now with full track setting and only changed it once to make it stiffer thats it lol
eyekyu Sep 10, 2010 09:41 AM
electronic damper? lazy much....
go with BC Racing
majinfajita Sep 10, 2010 12:05 PM
Originally Posted by initial_d2k (Post 8657610)
Cusco
Tein Flex
...and HKS
Still, remotely adjustable damping doesn't really mean as much if the dampers themselves aren't very good! Bear in mind I've only ridden in a Civic with them but I was not impressed with the performance of the Teins...since it adjusts only damping, you're basically going to find the one setting that works best and never touch them again.
The adjustment only helps if the dampers are dynamic to begin with (i.e. the Ohlins on my buddy's S60R, or any Audi with MRC), where the change in setting changes how the damper reacts altogether. Even with those systems, because the spring rate doesn't change, the effect is still noticeable but when running full soft or full hard, the damping is going to be over/under damped for the spring rate....
evil03 Sep 10, 2010 02:29 PM
^well said
bye2u Sep 10, 2010 02:32 PM
cusco and hks dont make a elect damper controller for the ralliart..
only coilover i know that has edfc is the tein flex
robyn402 Sep 10, 2010 03:16 PM
reason i really want it, with my work i have the potential to get moved to a city where the roads can vary between good and abosolute crap... so being able to soften up the suspension on the fly is useful...
i like a stiff suspension but its no good when the roads u drive on are comparable to a wash board
majinfajita Sep 14, 2010 11:43 AM
Wasn't talking about the RA in specific, since the previous poster mentioned Cusco.
Getting an adjustable setup isn't as catch-all as buyers may think.
terbo88 Sep 16, 2010 03:15 PM
Pretty sure the tanabe GF's for the RA have a electronic damper controller... ;)
Ps I saw you at the JDMST meet at hoxton park a few weeks ago bye2u. Your gpsports muffler looks hawt.
robyn402 Sep 16, 2010 06:31 PM
anyone have a link, i tried googling it and no dice, as well tanabe website has no listing for anything other then evo 8/9
terbo88 Sep 16, 2010 10:14 PM
My bad.. On here
http://www.jdmconcept.com.au/index.p...&mid=3&cid=143
They have the TEAS controller listed as a CY4A part. But then continue to say its only compatiable with pro-5 and pro-7 tanabe coilovers, not the GF coilovers.
Wether they make pro-5 or pro-7's for the RA, im not to sure dude.
robyn402 Sep 17, 2010 08:51 AM
well found what i was looking for.... cuscos only listed evo X for part numbers unless i looked in the wrong spot, took the suggestion on the teins
Tein Flex
CY4A 09+ FLEX RALLIART AWD part #DSE32-6USS4
$1660.00
http://www.tein.com/products/flex.html
http://www.tein.com/price/mitsubishi.html
http://www.tein.com/products/edfc.html
EDFC part # EDK05-12140
EDFC strut Kit part # EDK06-K4474
figure if anyone else comes across the part numbers for coils and EDFC's from other manufactures this would be a good place to post it
eyekyu Sep 18, 2010 07:28 AM
all i can say is g'luck gettin the rear motors connected...
you have no room, unless you start cuttin the frame of the trunk
robyn402 Sep 18, 2010 11:11 AM
that was the kinda the plan too cut a small hole
