Noise from turning
Ok guys got another one of those questions to see if anyone else has it or how to get rid of it. I got a clicking noise from turning hard when driving slow mostly backing out of things or pulling into things at low speeds like 10mph or lower it is very prominate. The noise seems to be coming from what sounds like directly behind the steering wheel, some kind of belt or pulley or something. I just newly installed about a month ago some springs, now it never did this prior to them, so i kno for sure it must be them that is the root cause for this. However do i need to get something checked?, do i need to have my alignment done? Just totally confused has to what to do to fix it as most things i do myself and i dont take to anyone. So if anyone else has this noise please post and let me kno im not alone
Originally Posted by AntiBlitz
(Post 8905152)
So my car has developed a new noise that doesn't sound good. When turning the wheel either direction I get a grinding/quick popping/creaking sound coming from the firewall area. It happens while sitting still or in motion and is most noticeable when pulling into or out of a parking spot (I think mainly due to the low speeds making it easier to hear). My first thought is upper strut bearing since the same thing happened on my GTI but that was more of a single pop like something that was wound up popping from tension. Being lowered is the main culprit in the GTIs and as my RA is lowered too it seems to be similar. Anyone have any ideas? |
^^ double post delete pls
(Post 8905152)
what type of clicking noise is it making? |
its a suspension noise. I get it when its cold, goes away once the car warms up.
nah cant be, like dajackson ended up saying in his post, its a rotational noise, hot or cold, its there, and its coming from the firewall area behind the steering wheel. Just think of like a chain n sprocket kinda noise in a box, this is how this sounds. Its not loud or disturbing just when people point it out to me when i drive the car i feel bad cuz its supposed to be nice. Not crealing and rattling and sounding like a neon
Originally Posted by Westbound&down
(Post 8911034)
(Post 8911663)
does it make this noise when turning the wheel or then its full lock? either side? when does it make this noise what are you doing when it happens?
and does this noise you hear sounds like this duh duh duh duh or is it a metal clicking? |
Originally Posted by evil03
(Post 8912390)
and does this noise you hear sounds like this duh duh duh duh or is it a metal clicking? Its a clicking, metal sound. |
yep dajackson hit that right on the head lol, it just sounds like the steering wheel is clicking as i spin it from behind the firewall. left and right, and at extremely low speeds like idling backwards or forwards where u have to muscle the wheel and not the inertia of the tire spinning helping u.
I had the same exact noise. I took it to the dealership and I had a bad wheel bearing. Got it replaced.
My mates EvoX just started doing this too (after being lowered for 8 months already).
Checked the strut brace (as this was an issus for someone else), and the strut's themselves. Still unable to find the cause of the issue. He's taking it back to the dealer next week so I'll let everyone know what they say. |
it just sounds like some sort of linkage or something, im really not sure, its so damn cold out im not going to go outside and play under my hood to find out what it is lol, so once u find out let me kno jcm! thanks
anit...
what wheels do you have what springs and how low are you? camber set up? i think i found out what your issue |
I get some noise when backing up and turning sharply because my aftermarket tires (stock size) rub slightly on the fender liner even on stock suspension.
