Ralliart/GTS Lancer Big Brake List [ BBK ]
Most of the Manufacturer lists show options for either Ralliart 09+/ Galant Fortis / CY4A / or CX4A depending on the Vendor.
*Prices shown are Street Price as of Posting this and subject to sales and market conditions. Stock Ralliart Front Rotor size: [296 x 24 mm] Stock GTS Front Rotor size: [296 x 26mm] Stock Ralliart & GTS Rear Rotor size: [302 x10mm] BBK Front Kits: AMS /Willwood 4-Pot / 2 piece rotors [298.45 x 31.75mm] [$1,439] -Discontinued Brembo GT 4-Pot/ 2 piece Drilled rotors [365 x 29mm] [1P1.8502A] [$2,846 ] Ceika BBK's 4,6,&8-Pot 2-piece rotor options [330 to 380mm options] [$959 to $2000] Drew CTS-V Brembo Conversion 6-Pot 1-piece Evo X rotors [350 x 32mm] [$1,399] -parralegend Review Kit requires Hub bolt holes drilled from 12mm to 14mm, shim required to return to OEM specs. Fastbrakes /Willwood 4-pot / 1 piece slotted & drilled Evo 9 rotors [320 x 32mm] [$919] -The NEWB Review K-Sport Pro Comp 8-pot / 2 piece slotted or drilled rotors [330 x ??mm] [BKMT290-831SO] [$1,567] 8-pot / 2 piece slotted or drilled rotors [356 x ??mm] [BKMT290-841SO] [$1,881] NFSLancerRA (Evom) Corvette C5/C6 Conversion kit - Discontinued BBK 1 & 2 -Discontinued PB Brakes (uk) [ships worldwide] 4-pot to 8-pot options 2 piece Slotted/drilled option Rotors [multiple sizes] [£629.00-£1,349.00] Pleasure Racing Service (JDM) 4-pot / 2 piece Sloted rotors [302 x 24mm] [S4] [MSRP $1,874] 4-pot / 2 piece Sloted rotors [324 x 24mm] [S4] [MSRP $1,950] 6-pot / 2 piece Sloted rotors [330 x 32mm] [S6] [MSRP $2,668] Sold at Super Autobacs stores in Japan/ importer (4-pot shown on RA Sportback) Rotora (JDM) 4-pot / 2 piece slotted rotors [330 x 30mm] [rfk.229.04] [MSRP $3,100] 4-pot / 2 piece slotted rotors [355 x 32mm] [rfk.229.05] [MSRP $3,370] 6-pot / 2 piece slotted rotors [355 x 32mm] [rfk.229.06] [MSRP $4,045] Stoptech 4-pot / 2 piece slotted rotors [328 x 28mm] [83.626.4300.71] [$1,858] 4-pot / 2 piece slotted rotors [355 x 32mm] [83.626.4700.71] [$2,345] The Brake Man / Map Performance 4-pot / 2 piece rotors [317.5 (12.5") x ?? ] [MSRP 1,530] |
BBK Rear Kits:
..work in progress. Ceika Evo X Rear Conversion K-Sport Pro Comp Pleasure Racing Service PB Brakes (uk) Rotora (JDM) Stoptech |
Excellent guide, why is this not sticky'd!!!
Here's another one, this is from Austraila tho so shipping might be a factor ;)
http://www.mrtperformance.com.au/performance/brakes/738-lancer-ralliart-big-brake-kit |
Added ceika and rear Evo X conversion to the list.
Excellent guide! I almost purchase an evo x BBK and thanks for this thread and other. I have found out that it is not a direct bolt-on. It is still possible, but the mounting brackets needs to be custom and it will most likely cost you an arm and a leg.
Not sure if this list is still being maintained but the AMS/Wilwood kit has been discontinued.
So I purchased my Ralliart awhile ago and it already had a big brake kit upgrade using C5 corvette calipers. Trouble is, I now need to replace the rotors but am unsure of what rotors are being used. Can someone assist me? Thanks in advance
Originally Posted by bjacoby00
(Post 11777507)
Hard to tell which one you have without measuring the current rotors and comparing it to the kit specs in those threads. |
Originally Posted by c08
(Post 11739971)
