Need help with replacing Hub-Bearing assembly
My left front hub sheered off from the bearing assembly and I need to replace it. The stock hub-bearing assembly on my 2011 Ralliart sedan looks to be pressed into the knuckle because there are no bolts attached. Anyone have experience pressing the assembly out to remove it, or does it need to be done at a shop?
The OEM part lists a bolt on but my car appears to have the pressed type. Any info will help. |
The front bearings are pressed in. The rears are bolted-on. Without an actual shop press, you're going to have a hell of a time getting it in and out successfully. If you're going to tackle it yourself, make sure you have a heavy duty set of snap-ring pliers, too, it'll save you a lot of hassle.
