THE Complete Evo X turbo swap parts list!
#123
Anything wrong with using used oil and coolant lines? Also I would assume if I were to buy an inlet tube and it doesnt come with bolts I would have to buy them since the ralliart intake doesnt have a bolted on inlet. Does any one know the part number for them?
#124
^Im wondering the same thing as you. Used lines are fine as long as they arent cracked or anything I believe. But Im wondering about the bolts for the inlet pipe too, and also the 2 small bolts that hold the oil line to the turbo? Is that listed on the first page? or does it come with the line when you buy it from mitsuparts? Washers too. Just those small details and parts im concerned about because i dont wanna go into a swap and find out im missing pieces.
#126
When changing from the td04 to the 05 the 02 housing has an extra bolt that goes into the turbo so u need to get one of those too. I ran into that but I was able to use one of the housing bolts that I order for the compresor housing bracket bolt I bought.
#127
Life just got easier:
http://www.evoxforums.com/forums/showthread.php?t=59085
#128
#130
anyone looking for a stock evo x downpipe for the conversion I have once since I sold my RA
https://www.evolutionm.net/forums/sa...ralliarts.html
#132
I was wondering well this ultimate racing down-pipe work for the turbo swap. I'm pretty sure it will work, but just want to make sure. Thank you.
http://www.ultimate-racing.com/Produ...ousingDP.shtml
#134
Anyone else try to modify the intake piping for the stock ralliart turbo? I'm doing the swap soon and already have an AEM intake setup that I recently put on there and don't wanna give up. I don't mind cutting pipes. Just need to know what I need to modify. Also, I already have an Evo x intercooler with UR upper piping and ralliart lower piping. Will I have to change any of that??
#135
You'll have to modify the recirc tube for your bov other than that no modifaction for piping or ic. I think you can use the RA intake but you will have to cut off some of the intake that will taken place by the turbo inlet on the X turbo that the RA does not have.
