Boost gauge question
Did some quick searching, couldn't find an answer to this. To the people running a boost gauge, which vacuum/boost line have you been tapping into? My first thought would be to tap into the line connecting the bypass valve to the intake mani (just put a T in the line). My second option would be to tap into the line for the FPR boost reference, which would let me know instantly if it happened to to come off under boost. My third option was to T into both lines, run a hose between these two Ts, with a T in the middle which runs to my boost gauge. This would let me know if either line came off.
What do u guys think?
Option 1 is what I was leaning to. Mad_SB, could you shed some light on why not to use #3? I figured since both lines draw pressure from the intake mani, they should see the same pressure.
I think the issue with #2 is that, in the event of a fault with the new boost hose connection, the fuel pressure regulator won't see its proper boost reference.
Which is a really Bad Thing at WOT.
Nobody wants to sacrifice their engine for the sake of a gauge that is ostensibly there for safety reasons!
Rich
Rich
Agreed, however I have seen cars running #1 setup with bpv opening/fluttering and compressor surge issues. My guess is that there were other factors involved that I don't know about, as well, I just know that it's happened.
As far as running at the FPR, with my AEM gauge at least, there is only a very short (4", if that) hose needed at the T and then it connects right onto the electrical sender portion. That way there are only wires, not hose, running the length of the engine bay, minimizing the possibility of pinching/cutting/burning/etc. the vacuum source hose.
Rich
Rich
While it is true that #2 will also let you know of the FPR line pops off.. a wideband will also do that without introducing an additional point of failure (the line from the T to the boost sensor, be it mechanical or electronic). #3 is the worst of both worlds in that you now have 3 potential failure points and any of which will result in lean in boost condition.
