dom 2.0 ralliart dyno results inside
I think its just the 91 octane and the 94 degree temperature hence a conservative tune with little timing...Or maybe the turbo is worn out...Was the turbo fresh? or used from the previous owner? I would think 26psi would give you lots of HP.
Low boost pressure, i would imagine, is the main reason for the low numbers. I'm sure the temps played a factor as well. These days everyone seems to tune for 25 - 26psi on pump gas. That turbo should easily still be in it's efficiency range at those boost levels. The boost curve needs a bit of work, but I think the tuner kept the boost low in the lower revs intentionally to avoid issues with the sst..... We forget that only a few tuners have access to the SST tables that need to be adjusted when running big boost on a quickish spooling turbo.
Honestly, I think you should PM Razorlab and see if he will do a remote tune for you... the more I look at your plot.... the worse the tune looks to me. Boost should not be all over the place like that with a 3 port (unless it was installed wrong, or the tuner has no idea how to tune ecu boost control). I'm willing to bet there is a solid 30 or 40 whp left with a good tune... not to mention it will feel a lot smoother.
I agree with the boost plot looking a bit strange... there's the normal increase until 5500, then the normal fall-off, then another peak at 57-5800, and then another fall-off, with a third peak at 6800. From other plots I've seen, the dip between the 5800-6800 just shouldn't be there. At 6500, you've got less than 22psi, and you should be over 24. The 2-3 psi drop here is reflected on your torque curve, a sharp drop and then a gradual drop until about 6800 where it holds for a bit. The plot is ragged here as well. Fix this area of the map and you'll see gains of 30whp at least in this area.
The major thing to think about is that this region of the map is where your car will spend most of it's time when you're at WOT. If you're drag racing (or doing any racing, really) fixing this zone will make a HUGE difference in your results.
Also, is it just me, or do your AFRs look strangely lean? I see you're holding a solid 12 from 4500-5800, then a high 11 until 6400, after which lean spool kicks off and you go rich.
Seems to me like he's being nice to the tranny in regards to torque
Back on topic though, the boost curve needs some work from ~5K on. See how that measurement point is showing ~23 psi, and the torque peaks ~200 rpm after that. From my understanding the boost s/b basically flat line the rest of the way....
I've found the innovate clamp works amazingly well to get "accurate" AFR readings at the tail pipe.
With a TP, the innovate clamp at the tailpipe matched a wideband at the downpipe exactly at WOT.
With a HFC, the innovate was only .2 off at WOT
Hmmm, interesting. So how does it generate the same value at the tailpipe as is being recorded from the downpipe; is there some sort of "correction-formula" attached to the displayed value?
