Ralliart AFR and Tuning Questions
Does anyone happen to know where I can find Merlins guide, as well as any other good meterial on tuning the car? I searched, but got useless results.
Also, anyone know what a safe AFR is at WOT in the RA? I installed my AEM intake this weekend and while I used to be around a 10.2 at WOT I'm not at a 12.1...
http://thefrost.net/randomfiles/tuni...GUIDE_V2-0.pdf
u got me a little worried cause i just installed my aem intake on gst tune also. check ur AIM, we can chat there
I've tuned my RA fuelling based on Merlin's guide - and direct input from loads of the helpful people here on EvoM. Invaluable stuff. I'm currently tuned for mid-to-low 11s at WOT, with a tiny bit of "lean spool" action in there to richen up when playing around on track.
I realise I "could" go leaner. One day I probably will retune it, when I'm more experienced. But 12.1:1 at WOT sounds leaner than anything that was recommended to me as being a good idea.
Rich
Rich
Rich
Rich
Thanks for the PM by the way.
I think 11.5 @ WOT is what most should aim for. Some tuners like to tune for 12, but with weather changes and how little more power you make at the reliability loss, doesn't seem worth it
anything over 12 isn't very safe imo. I would say 12.5 is starting to step into the danger zone
I have:
Depo Racing UICP
UR LICP
X OEM FMIC
Go Fast Bits BPV
UR DP
Depo Racing HFC
Magnaflow Catback
My tune was a modified V2.6 to accommodate the exhaust.
Do you not have a wideband?? BTW I responded on AIM.
Depo Racing UICP
UR LICP
X OEM FMIC
Go Fast Bits BPV
UR DP
Depo Racing HFC
Magnaflow Catback
The further on the edge, the hotter the intensity, you know...
Rich
how close it is to danger I think is irrelevant; just stay under 12
for reference, stock is around 9.5-10 if I'm not mistaken
Unfortunately i dont have a wideband and im trying to get one now cause im afraid to get on it now not knowing what afr im at, i may go back on stock tune cause then ill know im safe for a while. i didnt get ur message on aim for some reason but ill message u again later on
Rich
Rich
