How to get S-Sport mode & Launch Control on the Ralliart
Crak, Maybe you can put a table in your thread of the car year, market, rom id, and if they get LC or not.
User | Year | Market | ROM ID | S-Sport | Launch Control | TCU File |
EyeDreamt | 2011 | USDM | 56940007 | Yes | Yes | 8631B001.cff |
Is this the only thing we need, besides a laptop?
http://www.ebay.com/itm/Mitsubishi-M...161547&vxp=mtr
also useful info
you can run MUT3 SW on windows7
it runs on Internet Explorer (yes, i know!)
before you run MUT3 - quit any IE windows you have open
- put your IE into Compatibility Mode.
In W7 it will error when you load up MUT3. it does for me anyways. just kill the error popup and off you go
when you first connect the VCI - wait a while - it will need to update the VCI firmware in some cases. just let the MUT3 S/W do it's thing. look on the VCI screen for details of what it's doing before you go any further
Crak - the car i flashed was a 2009 car. but it already had a 2010 rom on it (as i had already tuned it). i manually entered a bogus VIN - and that worked too. it's more the chassis code part that i suspect determines what files it wants to use.
i wonder whether, if you manually input a VIN from say a 2011 or 2010 car into a 2009, will it load the corresponding RomID onto the ecu? I'll have a play down the track with this.
edit - i used B001 also. it seems to be a universal evo SST "rom" as best i can gather. I'm assuming it's the latest logic, too.
