Ralliart & Evo X MR TC-SST Flash Testers
#46
Thanks for this fantastic info and download files
I need some help tho.
I am trying to do Teach In
I allways get time out errors, I have my TI file in the XML folder
Any help appreciatied
Do i need some specific file?
Kind Regards
Matt
Kind Regards
Matt
#47
Is there a way to download my existing TCU? I figured i'd try to back mine up first before messing with reflashing
I have a 2008 MR with software 8631A3790B which seems to be older than the ROM in your doc (8631A3790C)
I figure i'd try the B151 TCU rom but I want to make sure I have a backup of my existing ROM first
How do I read/save my existing TCU rom?
#48
You can not read your ROM, you would have to use the 8631A3790C as back up
DO NOT Use B151 on a 2008 car, it will have issues, The best one for your car is B000
Matt
#49
1 Post
I also had issues with timeout but i was able to figure out, you can do 1 or 2 teaches, then you have to back up/close the program then do the 3rd and then do the same backup thing, then you can do the 4th.
#50
#51
will this work on an 08 ralliart gallant sst?
****TESTERS NEEDED****
I have been working diligently over the past few months trying to refine and test the flash capabilities of the Ralliart and Evo X MR TC-SST. I have done enough personal testing to be sure that the manual I've developed works as designed, but as with anything, since I've developed it I know that it needs to be "dummy-proofed" to make sure that all bases are covered. That's where I need your help. Each person identified will be given a set of instructions and a test methodology sheet that fits their specific vehicle. We need to identify as many variables as possible. The person needs to be versed on EcuFlash and it's tuning capabilities (Don't worry we won't be asking you to change any tuned settings, just be able to read them) and have an understanding of flashing.
There is always a risk when playing with TCU's and ECU's. I have personally tested multiple different failure methods on my own Ralliart and the TCU is a very robust system.
In order to participate I am requesting that you send a PM to me with your
Name :
Make :
Model :
TCU #: If unsure, just use handy chart and we will validate prior to testing
ECU #:
PC OS:
Country of Origin:
I will never ask for VIN information and I will not share any information unless pertinent to testing and providing instructions.
We have identified multiple flashes for the Evo X and Ralliart:
CZ4A (Evolution X MR)
2008 8631A749.cff = 8631A3790C
2009 8631B001.cff = 8631A8270B
2010 8631B001.cff = 8631A8270B
2011 and Up 8631B151.cff = 8631A8270A
CY4A/CX4A (Ralliart)
2009 8631B002.cff = 8631A8600B
2011 and Up 8631B002.cff = 8631A8600B
Ralliart ECU Maps:
53600008 2009 USDM Lancer Ralliart SST
53600009 2009 USDM Lancer Ralliart SST
53600010 2009 USDM Lancer Ralliart SST
53610009 2009 EDM Lancer Ralliart SST
53610010 2009 EDM Lancer Ralliart SST
53610012 2009 EDM Lancer Ralliart SST
53610013 2009 EDM Lancer Ralliart SST
55590006 2010 USDM Lancer Ralliart SST
55590007 2010 USDM Lancer Ralliart SST
56940007 2011 USDM Lancer Ralliart SST
56940009 2011 USDM Lancer Ralliart SST
56940010 2011 USDM Lancer Ralliart SST
56950006 2011 EDM Lancer Ralliart SST
58030005 2012 USDM Lancer Ralliart SST
58640002 2012 EDM Lancer Ralliart SST
59570004 2013 USDM Lancer Ralliart SST
Evo X MR ECU Maps:
52370023 2008 JDM Lancer Evolution X SST
52370024 2008 JDM Lancer Evolution X SST
52690019 2008 USDM Lancer Evolution X SST
52690021 2008 USDM Lancer Evolution X SST
52690022 2008 USDM Lancer Evolution X SST
52690024 2008 USDM Lancer Evolution X SST
53050006 2008 EDM Lancer Evolution X SST
53050007 2008 EDM Lancer Evolution X SST
53050009 2008 EDM Lancer Evolution X SST
53050011 2008 EDM Lancer Evolution X SST
53050012 2008 EDM Lancer Evolution X SST
54070007 2009 EDM Lancer Evolution X SST
54550003 2009 JDM Lancer Evolution X SST
55580005 2010 USDM Lancer Evolution X SST
55580006 2010 USDM Lancer Evolution X SST
56190002 2010 JDM Lancer Evolution X SST
56880005 2011 JDM Lancer Evolution X SST
56880009 2011 JDM Lancer Evolution X SST
56900007 2011 USDM Lancer Evolution X SST
56900009 2011 USDM Lancer Evolution X SST
56900010 2011 USDM Lancer Evolution X SST
56920006 2011 EDM Lancer Evolution X SST
56920008 2011 EDM Lancer Evolution X SST
57140001 2011 EDM Lancer Evolution X SST
57140003 2011 EDM Lancer Evolution X SST
58020005 2012 USDM Lancer Evolution X SST
59590004 2013 USDM Lancer Evolution X SST
59590005 2013 USDM Lancer Evolution X SST
Disclaimer:
I (we) as a community of geeks and car enthusiasts take no responsibility for the modifications that you choose for your vehicle. Each and every one of you inherits the full risk of performing this modification. There is no guarantee that this flash procedure will not damage your TC-SST. Mitsubishi can and will void your powertrain warranty if they realize that you have performed this modification.
****IF LOCAL TO COLORADO****
Please submit, I will pay for Dyno time to properly test vehicles and flash methods for each vehicle that I can personally monitor.
Name :
Make :
Model :
ECU #:
PC OS:
Country of Origin:
Ralliart ECU Maps:
Evo X MR ECU Maps:
Disclaimer:
hey I have a 2008 Gallant Ralliart looking for launch control (s-sport) can I do this myself?
#52
1 Post
No as your car does not have the same transmission. The only hope would be to get your transmissions code and rewrite it. You might be able to use Can Pass thru to write it but you cant use our code to just flash yours.
#55
had this done for over 6 months now. Never had Rev hunt, never had to do a teach in and it grabs hard. LC done it only a handful of time and damn does it pick up quick with our small turbo.
Figure I shared after a prolonged use.
franzcars
Jul 26, 2023 09:27 AM
crak
906
Aug 14, 2022 02:41 PM
