Ralliart & Evo X MR TC-SST Flash Testers
Old May 18, 2014, 05:33 PM
vaqusis's Avatar
****TESTERS NEEDED****
I have been working diligently over the past few months trying to refine and test the flash capabilities of the Ralliart and Evo X MR TC-SST. I have done enough personal testing to be sure that the manual I've developed works as designed, but as with anything, since I've developed it I know that it needs to be "dummy-proofed" to make sure that all bases are covered. That's where I need your help. Each person identified will be given a set of instructions and a test methodology sheet that fits their specific vehicle. We need to identify as many variables as possible. The person needs to be versed on EcuFlash and it's tuning capabilities (Don't worry we won't be asking you to change any tuned settings, just be able to read them) and have an understanding of flashing.
There is always a risk when playing with TCU's and ECU's. I have personally tested multiple different failure methods on my own Ralliart and the TCU is a very robust system.
In order to participate I am requesting that you send a PM to me with your
Name :
Make :
Model :
TCU #: If unsure, just use handy chart and we will validate prior to testing
ECU #:
PC OS:
Country of Origin:
I will never ask for VIN information and I will not share any information unless pertinent to testing and providing instructions.
We have identified multiple flashes for the Evo X and Ralliart:
CZ4A (Evolution X MR)
2008 8631A749.cff = 8631A3790C
2009 8631B001.cff = 8631A8270B
2010 8631B001.cff = 8631A8270B
2011 and Up 8631B151.cff = 8631A8270A
CY4A/CX4A (Ralliart)
2009 8631B002.cff = 8631A8600B
2011 and Up 8631B002.cff = 8631A8600B
Ralliart ECU Maps:
53600008 2009 USDM Lancer Ralliart SST
53600009 2009 USDM Lancer Ralliart SST
53600010 2009 USDM Lancer Ralliart SST
53610009 2009 EDM Lancer Ralliart SST
53610010 2009 EDM Lancer Ralliart SST
53610012 2009 EDM Lancer Ralliart SST
53610013 2009 EDM Lancer Ralliart SST
55590006 2010 USDM Lancer Ralliart SST
55590007 2010 USDM Lancer Ralliart SST
56940007 2011 USDM Lancer Ralliart SST
56940009 2011 USDM Lancer Ralliart SST
56940010 2011 USDM Lancer Ralliart SST
56950006 2011 EDM Lancer Ralliart SST
58030005 2012 USDM Lancer Ralliart SST
58640002 2012 EDM Lancer Ralliart SST
59570004 2013 USDM Lancer Ralliart SST
Evo X MR ECU Maps:
52370023 2008 JDM Lancer Evolution X SST
52370024 2008 JDM Lancer Evolution X SST
52690019 2008 USDM Lancer Evolution X SST
52690021 2008 USDM Lancer Evolution X SST
52690022 2008 USDM Lancer Evolution X SST
52690024 2008 USDM Lancer Evolution X SST
53050006 2008 EDM Lancer Evolution X SST
53050007 2008 EDM Lancer Evolution X SST
53050009 2008 EDM Lancer Evolution X SST
53050011 2008 EDM Lancer Evolution X SST
53050012 2008 EDM Lancer Evolution X SST
54070007 2009 EDM Lancer Evolution X SST
54550003 2009 JDM Lancer Evolution X SST
55580005 2010 USDM Lancer Evolution X SST
55580006 2010 USDM Lancer Evolution X SST
56190002 2010 JDM Lancer Evolution X SST
56880005 2011 JDM Lancer Evolution X SST
56880009 2011 JDM Lancer Evolution X SST
56900007 2011 USDM Lancer Evolution X SST
56900009 2011 USDM Lancer Evolution X SST
56900010 2011 USDM Lancer Evolution X SST
56920006 2011 EDM Lancer Evolution X SST
56920008 2011 EDM Lancer Evolution X SST
57140001 2011 EDM Lancer Evolution X SST
57140003 2011 EDM Lancer Evolution X SST
58020005 2012 USDM Lancer Evolution X SST
59590004 2013 USDM Lancer Evolution X SST
59590005 2013 USDM Lancer Evolution X SST
Disclaimer:
I (we) as a community of geeks and car enthusiasts take no responsibility for the modifications that you choose for your vehicle. Each and every one of you inherits the full risk of performing this modification. There is no guarantee that this flash procedure will not damage your TC-SST. Mitsubishi can and will void your powertrain warranty if they realize that you have performed this modification.
****IF LOCAL TO COLORADO****
Please submit, I will pay for Dyno time to properly test vehicles and flash methods for each vehicle that I can personally monitor.
Old May 20, 2014, 01:34 PM
nunyas's Avatar
What are your requirements to qualify for the test, and what exactly is being tested here? Sorry if I'm asking obvious questions, but the body of the original post doesn't seem to answer either of these.
Old May 20, 2014, 02:05 PM
total0wnage's Avatar
im interested but also want to know what is being tested- the methods of flashing?
Old May 20, 2014, 03:15 PM
tazz33's Avatar
I'm interested as well!!! Would be cool to be able to set things up for it with ECUFlash with this also be setting it up for S-Sport and launch control?
Old May 20, 2014, 10:27 PM
vaqusis's Avatar
There are multiple aspects that need to tested. First, yes this will give Ralliarts S-Sport and Launch Control using Tactrix. The requirements are pretty simple, Evo X or Ralliart with SST and willing to spend some time reading and flashing. The more variations in vehicles the better the testing.
#1. The flash/Re-Flash method. (Flash from A749 to B001 and back....etc)
I have written instructions to flash USDM, EDM and JDM TC-SSTs. But my only "test" car is my own which is a USDM 2010 Ralliart. Via PM I have been able to walk someone from Brazil through a flash on their vehicle which worked perfectly. The instructions for each set (USDM, EDM and JDM) all need to be fully tested.
#2. TCU vs. ECU Compatibility.
We have noticed that some versions of TCU and ECU don't play well together. We have already identified 1 ROM that doesn't like being upgraded. An Evo X with 52690019 2008 USDM Lancer Evolution X SST was flashed from A749 to B001 and it caused it to have a CEL. The car performed perfectly fine but the CEL would just stay on the car no matter how many times it was cleared. The fix was to upgrade the ECU to 52690021 2008 USDM Lancer Evolution X SST. Functionally the vehicle was fine and ran great but somewhere there is a direct correlation between the ECU and TCU files that didn't match.
#3. Clutch Pressures; Shift Points; (Overall Butt Dyno)
Pretty self explanatory. What's the differences between the TCU maps.
#4. Teach-In Procedures
Same instructions as the flash procedures but refine whether it's actually required on a reflash/flash or just good practice.
I hope this has answered most of your questions.
The ultimate goal is to verify the instructions for flashing/re-flashing work as designed and to help pave the way for further development on TCU .cff file modification and tuning.
****We have already discovered that the clutch pressure is actually backwards from originally thought. Normal produces more clutch pressure according to the TCU than Sport and S-Sport****
Chaicolan (Oct 16, 2017)
Old May 22, 2014, 07:19 AM
BigDsRalli's Avatar
Wait, I can get S-Sport without going to the stealership...and the worst thing that can happen is I can blow up my $5k transmission?
I'M IN!
Old May 23, 2014, 11:35 PM
bunnishiwa's Avatar
PM'd
Old May 24, 2014, 09:18 AM
vaqusis's Avatar
The TC-SST was designed with S-Sport. They chose not to equip the Ralliart with it. I've been running it from January and nothing wrong at all and many have had it longer. The biggest risk could be bricking the TCU.....and trust me I tried. It's actually quite hard to do.
I'M IN!
Old May 24, 2014, 01:33 PM
BigDsRalli's Avatar
Let's do it!
Old May 30, 2014, 10:01 AM
CFMP RAblue's Avatar
PM'd
So you have done it once?
Old May 31, 2014, 07:10 AM
BigDsRalli's Avatar
OP hasn't responded yet. I'm ready and willing to be the guinea pig.
Old Jun 6, 2014, 05:23 AM
vaqusis's Avatar
I'm still here. The testing worksheets are almost done and I have set aside a repository for all files and configurations tools required. My goal is for the manual and testing parameters to be sent out on Friday of next week. Hopefully this will give everyone the time to test and play before the end of the month. I seriously want to make this completely free for the community.
Old Jun 6, 2014, 07:39 AM
BigDsRalli's Avatar
This is going to be huge.
Old Jun 6, 2014, 01:20 PM
NFSLancerRA's Avatar
I am in Orlando and am willing to help anyone get this done. There are a few RA owners around here that I am sure are interested in doing this.
Old Jun 6, 2014, 05:49 PM
from ur original post u said that NORMAL mode has more clutch pressure than sport and super sport? was there a discussion about this on this forum or another? if so id like to read ive been out of country and have been behind on my daily forum reading. PS im also willing to test when the stuff is ready
Quick Reply: Ralliart & Evo X MR TC-SST Flash Testers
