GST Motorsports |
Sep 3, 2010 07:26 PM |
2009+ Ralliart Evoscan addresses / info
This will evolve into a central thread where people can find correct Evoscan address's to properly log their 2009+ Ralliarts.
First, check this first post for your ROM ID and check for the *known working* address's for your ROM ID / Model Year and Market.
If what you are seeking is not listed then:
Second, post what ROM ID / Model Year and Market you have and then what you are trying to log and with what current address.
Example:
ID 55590342
2010
USDM
Looking for:
Manifold Air Temp
Currently logging request address: 23808632
Does not log correctly
ID 55590007
2010
USDM
Currently logging correctly:
RPM
Load
TimingAdv
Barometer
PSI
Knock Sum
Accel Pedal Position
TPS
Active WGDC
IPW
IDC
Corrected Timing Advance
Manifold Air Temp
Coolant Temp
Intake Air Temp
Speed
STFT
LTFT idle
LTFT Cruise
LTFT In Use
Boost Error (for psi-target, needs rom mods)
Front Oxygen Sensor
Rear 02
Knock Voltage
Battery Level
Injector Latency
InVVT (target)
ExVVT (target)
InVVT (actual)
ExVVT (actual
MAF Volts
MAF Airflow
Altmap Status (for Tephra map switching, needs rom mods)
SST Transmission Temp
External Wideband A/F Ratio
XML:
Code:
<DataListItem DataLog="Y" Color="" Display="2-Byte RPM" LogReference="2ByteRPM" RequestID="2380875c" Eval="3.90625*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor=".1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Load" LogReference="Load" RequestID="23808784" Eval="x*10/32" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="30" ScalingFactor=".1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="TimingAdv" LogReference="TimingAdv" RequestID="23808A1F" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-10" GaugeMax="50" ChartMin="-10" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Barometer" LogReference="Baro" RequestID="2380AA4D" Eval="x*0.07251887" Unit="psi" MetricEval="x/2" MetricUnit="kPa" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="50" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="PSIG" LogReference="PSIG" RequestID="2380872E" Eval="(x/4*0.1953125)-[Baro]" Unit="PSIG" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-15" GaugeMax="35" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Knock Sum" LogReference="KnockSum" RequestID="23808A63" Eval="x" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Air/Fuel Ratio (Map)" LogReference="AFRMAP" RequestID="2380890d" Eval="(14.7*128)/x" Unit="AFR" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Accel Pedal Position" LogReference="APP" RequestID="238095FD" Eval="(x-32)*129/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="TPS" LogReference="TPS" RequestID="2380870D" Eval="x*100/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Active WGDC" LogReference="WGDC_Active" RequestID="23808b6d" Eval="x/2" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="IPW" LogReference="IPW" RequestID="2380AA88" Eval="x/1000" Unit="ms" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="IDC" LogReference="IDC" RequestID="23808763" Eval="[IPW]*31.25*x/1200" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Corrected Timing Advance" LogReference="Corr_TimingAdv" RequestID="238089ff" Eval="x-20" Unit="degrees" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="23808672" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="2" GaugeMin="-10" GaugeMax="200" ChartMin="-10" ChartMax="200" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Coolant Temp" LogReference="ECT" RequestID="23808653" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Engine Coolant Temperature" Priority="3" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Intake Air Temp" LogReference="IAT" RequestID="2380866D" Eval="1.8*x-40" Unit="Deg F" MetricEval="x-40" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="-10" GaugeMax="130" ChartMin="-10" ChartMax="130" ScalingFactor="1" Notes="Intake Air Temperature" Priority="3" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Speed" LogReference="Speed" RequestID="238087FF" Eval="x*1.243" Unit="mph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="250" ChartMin="0" ChartMax="260" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="STFT" LogReference="STFT" RequestID="238088b0" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="LTFT idle" LogReference="IdleLTFT" RequestID="23804573" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="LTFT Cruise" LogReference="CruiseLTFT" RequestID="23804575" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="LTFT In Use" LogReference="CurrentLTFT" RequestID="238088C1" Eval="(0.1953125*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="WGDC Correction MUT" LogReference="WGDCCorr" RequestID="23808783" Eval="0.5*x-64" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Boost Error" LogReference="BoostError" RequestID="238085A2" Eval="(x-128)*0.19347/4" Unit="psi" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-6.1" GaugeMax="6.1" ChartMin="-6.1" ChartMax="6.1" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Front Oxygen Sensor" LogReference="FrontO2" RequestID="2380867d" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Rear O2" LogReference="O2Sensor2" RequestID="23808681" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Knock Voltage" LogReference="KnockVolt" RequestID="2380872b" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Battery Level" LogReference="Battery" RequestID="23808703" Eval="0.07333*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="3" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Injector Latency" LogReference="InjectorLatency" RequestID="23808945" Eval="x" Unit="ms" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="InVVT (target)" LogReference="InVVTtarget" RequestID="23809526" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="ExVVT (target)" LogReference="ExVVTtarget" RequestID="23809532" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="InVVT (actual)" LogReference="InVVTactual" RequestID="2380955e" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="ExVVT (actual)" LogReference="ExVVTactual" RequestID="2380956A" Eval="(x-4096)*-0.01953125" Unit="Deg" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="-40" GaugeMax="50" ChartMin="-40" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="MAF Volts" LogReference="MAF" RequestID="23808F78" Eval="x/1024*5" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="MAF Airflow" LogReference="MAFgs" RequestID="238087f8" Eval="x*0.02" Unit="gs" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Altmap Status" LogReference="Altmap Status" RequestID="23805000" Eval="x" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="SST Transmission Temp" LogReference="SST_TM_Temp" RequestID="CAN28-0" Eval="x-50" Unit="Deg F" MetricEval="x-50" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="0" GaugeMax="1000" ChartMin="0" ChartMax="1000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="#90ff00" Display="External Wideband A/F Ratio" LogReference="WideBandAF" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="10" Notes="Plug in your serial port from your wideband oxygen sensor if you have one." Priority="1" Visible="False" />
ID 53600010
2009
USDM
RPM
Load
TimingAdv
PSI
Knock Sum
TPS
Active WGDC
IPW
Coolant Temp
Intake Air Temp
Speed
MAF Volts
XML
Code:
<DataListItem DataLog="Y" Color="" Display="Throttle Posn" LogReference="TPS" RequestID="23808701" Eval="(x-32)*129/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="2-Byte RPM" LogReference="2ByteRPM" RequestID="2380874E" Eval="3.90625*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor="0.1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Load (Fuel)" LogReference="LoadFuel" RequestID="23808776" Eval="x*10/32" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="340" ChartMin="0" ChartMax="340" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="TimingAdv" LogReference="TimingAdv" RequestID="23808A0F" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-15" GaugeMax="50" ChartMin="-15" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Knock Sum" LogReference="KnockSum" RequestID="23808A53" Eval="x" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="PSIG" LogReference="PSIG" RequestID="23808722" Eval="(x/4*0.19347)-14.5" Unit="PSIG" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Intake Air Temp" LogReference="IATS" RequestID="23808659" Eval="1.8*x-40" Unit="deg F" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Coolant Temp" LogReference="CTS" RequestID="23808647" Eval="1.8*x-40" Unit="def F" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Speed" LogReference="Speed" RequestID="238087EF" Eval="1.26*x" Unit="mph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="MAF Volts" LogReference="MAF" RequestID="23808F58" Eval="x/1024*5" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="2" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Battery" LogReference="Battery" RequestID="238086F7" Eval="x*18.75/255" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="External Wideband A/F Ratio" LogReference="WideBandAF" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="10" Priority="1" Visible="False" />
