-   09+ Ralliart Engine/Turbo/Drivetrain (https://www.evolutionm.net/forums/09-ralliart-engine-turbo-drivetrain-309/)
-   -   Best BOV's? (https://www.evolutionm.net/forums/09-ralliart-engine-turbo-drivetrain/694384-best-bovs.html)
Vegeta_Ra Jun 30, 2014 02:17 AM
Best BOV's?
I have 2010 Ralliart. It's completely stock.. I want to start upgrading it. I'd like to have a louder bov above stock and the evo.. I just love the sound :)
Will it have to be tuned or anything? Or are their some that don't require a tune?
Thank you
joseph15712 Jun 30, 2014 03:00 AM
Turbosmart dual port
Jay10Ralliart Jun 30, 2014 06:57 AM
^^^That one didnt work out so well for my car. I ended up switching back to the Evo X bpv. These cars need to run recirculated so being louder isnt going to happen. If you run an intake you will be able to hear the intake better with an aftermarket bpv, but an intake requires a tune. The only other bpv Ive heard that runs really well besides the Evo X one is the Synapse one.
spider21 Jun 30, 2014 08:17 AM
Just buy the Cobb BPV
neogeo64 Jun 30, 2014 08:34 AM
A lot of Evo MR's and RA's seem to like the GFB T9033.
You can recirculate 90-95% and vta the other 5-10% for sound.
spider21 Jun 30, 2014 07:11 PM
You can get the sound with an open air filter :-)
oscarquinones Jun 30, 2014 08:19 PM
I use the EVO 9 stock bov crush and it work for me better that a lot aftermarket.
Corrupter Jul 1, 2014 01:43 PM
I use the GFB adjustable BOV and VTA ~20-30% with no issues. Not too loud, but definitely loud enough for me. I tried it at 50% VTA and I felt that it was a little too loud and attracted more attention than I wanted.
Noveske Jul 2, 2014 11:45 AM
First, the main purpose of a BPV for our cars is to release pressure from the intake tract. The sound is just a byproduct of the BPV/BOV. If you must get a BOV, make sure it can recurculate air back. The ones that release all of it out aren't suited for our cars. It throws the air flow meter off and can cause issues. I suggest picking up an OEM evo x BPV. Super cheap and gets the job done. However, turbosmart offers one for the ralliart which will make the cool vent noises that a bov makes.
Vegeta_Ra Oct 14, 2014 04:48 PM
I purchased both the evo x crushed and the gfb respons. I like the gfb vented at 10-20% but noticed my mileage dropped and at times when it would boost, and I'd let off the throttle, there was like a surge or something. So I'm back with the evo x and am probably selling the gfb
.M. Oct 14, 2014 06:13 PM
Car came with a HKS vta setup when I bought it. Ran terrible. Now I'm running a Tomei strengthened evo bov (recirc).
Vegeta_Ra Oct 15, 2014 02:40 PM
How does the Tomei sound?
.M. Oct 15, 2014 04:54 PM
Same as stock. Here's the product description...
"The Evo comes equipped with a factory blow off valve to protect the compressor on the turbo, when you "accel-off".
On the Evo 7 and 8, the factory blow off valve is made out of plastic, which can expand and result to leaking even under normal driving. Plastic blow off valve can also wear out over time resulting in leaks. The Evo 9 blow off valve is made out of steel, however the spring is inadequate to hold higher boost levels. The solution to solving these issues without having to modify anything under the hood is the TOMEI BOV. Made to replace the OEM bov with exact same fitment! With everything designed same as the OEM bov, the Tomei Bov is able to hold higher boost levels without any modification."
MetalGear214 Oct 15, 2014 05:16 PM
I have a GFB T9033 for sale! PM me for an offer LOL. Sorry to thread jack.
Burnstormer Oct 16, 2014 12:57 PM
I use a Synapse DV on full recirculation. Hear it every time I lift off the gas pedal due to open element intake.
