SST trans probs Kinda
Hey what's up guys I bought a 2010 RA few weeks back from a used car dealer. Did the trans fluid swap and external filter with a buddy who has had a few RA's. It fixed the issues I had like not shifting in to 3'4'5 gears running bad and not shifting. Now every morning when I start my car the service trans light pops on and you can here the trans whine and It wont go into gear but if I let it run for a few mins and then shut it off and restart the car it goes away and I wont have any problem's and it runs fine. Do you guys know what this could be any information would be appreciated thanks.
without the code the trans is throwing up its tough to geuss
Did the used car dealer give any warranty at all?
Have mitsu dealership fix it and bill the used car dealer... |
Update my timing chain was super streched out and i they replaced the ecu for recall i had a stuck solenoid in the trans and a blockage in the 3,4th they said the trans prob was casuased by the car being in limp mode and that the timeing chain was the cause of all the probs will know if its good to go thursday they replaced the chain with the new one they have herd it upgraded from the stock one they remaped the new ecu they said with the evo stuff but i doubt it and they did all the timing parts
Bullshark!
The timing chain/limp mode can not cause the tranny issues you describe. Keep documenting and getting it fixed right away (before the used car dealership can start ignoring you). |
