Cig lighter wiring
Cig lighter wiring
I wanna install LEDs in my car using the power source from my cig lighter. I was wondering how i could get the cig lighter inside between the seats. Pictures would be great
hey man. check this out. This is what I am gonna do when I wire in my radar detector and navi. also gives access to more stuff for future.
https://www.evolutionm.net/forums/ev...ng-else-7.html
Sorry I don't. I am not one for cutting into the cars stock system. If you build the distro block you can just run wires to it and it is easily taken out. I am hoping to have some time for it in the near future, with a 2 kids and a wife it's difficult to spend time on the car.
to get access to the cig lighter wiring you will need to take apart the center console and simply lift up the back section. to wire to that what i did was simply unplug it which leaves 1 adapter and the cig plug which has 2 prong that go into the adapter, 1 prong is positive and 1 is ground, just put your wire through the appropriate hole in the prong then take the adapter and force it back on, wiring is usually thin so it should go on without much force. and that's the way i did it to avoid splicing factory wiring
Ok so I did this and when I turned key so power would go to cig plug it popped fuse... I replaced fuse with a 20 instead of the 15 and tried again this time melted wires extremely fast.... what am I missing. I have it all connected to a on off switch?
sorry for the old thread revival.
You are making contact somewhere that you are not supposed to which is causing constant flow of too much current, causing the fuse to pop and to ultimately melt wiring. This is why fuses are set at a certain amperage, to prevent wiring damage like that.
I suggest trying another method for sourcing power. The easiest, and most easily reversible, safe way to do so is to use a fuse tap like this one:
You basically unplug a 10A fuse from the fuse box and plug this in its place. Then install 2 10A fuses into this fuse tap. One fuse will run your original fused circuit as normal. The second fuse is used to create a completely new circuit that runs independantly of your circuit that you tapped into. Use the red wire lead coming from the fuse tap as your power source for your new component that you are adding.
Im installing led strips one under driverside dash lighting up pedals, one in door molding and same with passenger side attached to a switch where the heated seats switches are for those who have heated seats... Just trying to find good ground believe i keep popping fuse because not finding a good ground. a pic would also help if you know of one in the center console area.
Devon505
Aug 5, 2015 11:10 AM
Pbayr0lla321
May 16, 2012 09:21 AM
steven88
23
Feb 26, 2010 06:57 PM
