How to: Replace Blower Motor and Blower Motor Resistor
Old Apr 2, 2017, 05:04 PM
GetFoxed's Avatar
No heat or air blowing from the dashboard, here is my How To replace the blower motor fan and Blower Motor Resistor. Performed on a 2009 Ralliart. Approx Time to complete 25 minutes.
Tools Needed:
-Stubby #2 Phillips Screw Driver
-Small flat head screw driver
-Knee Pads
Tools Needed
Parts Needed/Used:
-FRAM CF10140 Fresh Breeze Cabin Air Filter
Amazon Amazon
-Wells JA1807 HVAC Blower Motor Resistor
Amazon Amazon
-TYC 700239 Replacement Blower Assembly
Amazon Amazon
This is includes changing the cabin air filter, shown here in this link:
https://www.evolutionm.net/forums/09...ir-filter.html
Step 1) Remove your Glove Box (Noted in the link above)
Removed Glove Box
Step 2) Remove Access Panel -> Remove 2 Plastic Panel Inserts Clips
-Pop Out the 2 Panel Clips, using the small flat head Screw driver. (Orange Arrows) The panel should be loose to remove and allow access to the fan motor and fan resistor now.(Green Highlight)
Remove Panel
Step 3) Remove Blower Motor Resistor
-Remove the 2 screws (Orange Arrows) Unplug the Connector to the resistor, done by hand (Green Highlight) This is where the stubby screwdriver is NEEDED.
Remove Resistor
Step 4) Remove the Fan Blower Motor
-Remove the 3 Phillips Screws, stubby or standard screw driver can be used. (Orange Highlighted) Unplug the Fan Motor Connector, done by hand. (Green Highlighter) Remove clear plastic flex tube from blower motor, done by hand. (Red Arrow)
Remove Blower Motor Fan
Step 5) Replace Blower Motor with New Part & Blower Motor Resistor with New Part
-Plug Everything back in and screw it all back into place.
New Parts, Plugged In & Screwed back into place.
Step 6) Replace Access Panel
- Put Access Panel Back into place that was removed in Step 2
- Insert 2 Clips to hold panel into place
Step 7) Insert New Cabin Airfilter & Install Cabin Airfilter Cover - Noted here:
Step 8) Reinstall Glove Box
- Snap Glove Box into place & reinstall the glove box shock.
Snap Glove Box into Place
Install the Glove Box Shock
Put your Stuff back in the Glove Box. Done.
Step 9) Test Everything out, and you should be good to go.
Step 10) Drink a Beer and Clean Up.
2009 Ralliart
Old Apr 3, 2017, 05:43 AM
Veronica's Avatar
Thanks for the great write-up!
Old Jul 10, 2017, 01:01 AM
Bonnie's Avatar
very useful, thanks
Old Jun 12, 2019, 04:56 PM
blue50418's Avatar
2010 Mitsubishi es lancer I replace blower motor and resistor still not working, any idea whats can the problem be
valthekidd
Lancer How Tos / Installations
Jul 25, 2019 03:44 PM
rayman0690
Aug 4, 2012 12:22 PM
peeps
Jul 25, 2011 02:28 PM
dp1986
Feb 10, 2009 03:22 PM
Quick Reply: How to: Replace Blower Motor and Blower Motor Resistor
